Need Help - Converitble tonneau release will not work
Old Mar 14, 2009 | 02:01 PM
ConvertibleZ's Avatar
I parked my convertible for the winter and the release switch on the center console worked fine. Now it does not work. Is there anyway to get the tonneau to release manually? Any suggestions on how to fix it?
Old Mar 14, 2009 | 05:01 PM
mikeiaz's Avatar
Re: Need Help - Converitble tonneau release will not work
it can be manually released - i have never had to and don't recall the exact procedure, but use the search too at top bar and you should be able to find prior posts with this info
Old Mar 14, 2009 | 09:15 PM
Scooby Doo's Avatar
Car: 92 Trans Am Convertible
Engine: 5.0L
There are wire cables w/ loops on the end on each side to release the tonneau, fold you back seat down and look in the area where the side panels meet the seats.
I remember seeing them when I was replacing my rear shocks last time, although I have never used them.
Old Mar 14, 2009 | 11:48 PM
mister_hudson's Avatar
Car: '92 Z28 Convertible
Engine: 305ci TPI
Transmission: 700R4 shifted
Axle/Gears: 2.73 (for now)
Just give them a light tug towards the center of the car & you're back in business...
Old Mar 15, 2009 | 09:43 AM
67tothefuture's Avatar
Car: 1991 Z28 Convertible
Engine: 305 tpi
Transmission: 700 r4 Auto
Make sure the tonneau top is all the way down. I have problems with mine not latching down far enough. I would ear clicking but it would not release. I have to put a little pressure down on the left side of the top when I push the switch and then it opens.
Old Mar 15, 2009 | 10:04 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Now for getting it to work as it is supposed to. Does your hatch pull-down motor work or has someone messed with it and converted it to a slam latch? The pull-down unit must work corectly for the tonneau switch to function. The striker-sensing switch of the pull-down motor is tied in as a safety to the tonneau release. On an automatic car the neutral-safety switch is also used as a safety to prevent you from opping it accidently while driving. Try pulling up on the parking brake a couple of clicks and see if it will pop.
Lon
Old Mar 24, 2009 | 09:14 PM
Thank you my friend. I pulled the back cover off inside my trunk to run some sub woofer wiring and found that the striker harness was un plugged. I must have done that when replacing a rear tail light bulb over the winter. I also pulled up on my e-brake handle to activate the e-brakes since I re-shoed my rear brakes and "Bam" my rear hatch release now works.
I really appreciate the help.
Old Mar 27, 2009 | 02:21 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
Lon
Hey Lon, mine is doing the same thing. I converted my auto 92 Z into a six speed and now my electric tonneau wont release? I did find out that if I manually ground out the switch, the solenoids will work, but then my starter wont work when I turn the key over!?!? I remove the jumper ground wire and then my solenoids stop working again and the car will start? LOL Im I missing my auto saftey switch since I converted the car over to a manual? Thanks in advance!
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Fronzizzle
Aug 17, 2015 02:52 PM
