spare cover remake
Old Jul 14, 2009 | 09:54 PM
Wild Weasel's Avatar
Car: 1989 RS Drop-Top
Engine: 305 TBI
spare cover remake
The spare cover is absent from my 89 RS vert. Got one from a coupe but it is too long. Since I do not have the old one and there are none in the area that have the plastic covers, is there a diagram somewhere that will tell a person where and how the cover is too be cut. I know I can cut and recut but a mistake is a mistake and there just are not that many around.
Old Jul 15, 2009 | 12:02 AM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
Re: spare cover remake
Did you post a want ad in the classifieds section? I'm sure someone is parting one out that would be more than willing to sell you the cover!
Old Jul 15, 2009 | 08:44 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I can measure mine later for ya.
if you have a coupe one it really easy to cut.
Old Jul 15, 2009 | 09:11 AM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If I was in a pinch, this is what I would do... Ultimately it will be determined by your experience and your skills...
I want to think that both sides of mine are more or less trimmed the same. So if you have the Left side, remove it, and make a cardboard template., take some measurements and then put your template on the part you want to cut. make it longer than what you measure at first and then start sneaking up on it.
I would NOT use a reciprocating saw like a jig saw, or scroll saw, it may seem to be the easy way, but the reciprocating action may cause the plastic to crack, and you do not want that... Ideally you want to use something like a Band saw, or a hand saw (like a coping saw) The coping saw may be really ideal as it should cut reasonably quick... Once done, take a file and clean up your edge. If you use a coping saw, you may have to cut out sections as you go to clear the frame of the saw...
Old Jul 15, 2009 | 07:12 PM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Dremels work great for plastic. Good for control and detail too.
Old Jul 16, 2009 | 01:41 PM
Engine: 305 TBI
I just found a set of pictures on the forum of someones open trunk showing the spare, jack and the cover that I'm trying to make. It may be just the thing I've been seeking. Going to go sharpen the Dremel.......Thanks all....
Old Jul 17, 2009 | 09:55 AM
Axle/Gears: 3.08
Did the pic look like this?
Old Jul 17, 2009 | 08:13 PM
Firebird90's Avatar
Car: Firebird SSA
Engine: 3.1
I have an extra cloth one.
Let me know if you need it....
Old Jul 18, 2009 | 07:33 PM
Engine: 305 TBI
Yep ! that's it uh huh uh huh. Going to put a graph to it and transfer it to the one I have. Neato..... Now if I can find the right jack. Got one from an older one. but for now it works. Don't have the right spare anyway. Yet.... I must be nuts.
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:13 PM
Denricci22
Sep 18, 2015 09:02 AM
Nick McCardle
Sep 10, 2015 08:36 PM
