trunk hinge removal?????
Old Aug 7, 2009 | 09:59 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
ok i have a question. i got into a lil body damage a while back. my trunk hinges are bent and i need to remove them to be able to either install a new pair or heat them and bend them back to close to there orignal shape. i have the trunk lid off, but how do i get these off? i cant feel a bolt and i cant see a way to get them off.. is there a way to get them off? without haveing to do some sergery to the car? ive at the point where im about to cut away a lil panel on the inside of the car to access them and take them off and reinstall with a regular bolt.
Old Aug 7, 2009 | 10:58 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
Re: trunk hinge removal?????
probably inside the quarter...
Old Aug 8, 2009 | 10:06 AM
ah1s's Avatar
the hinge is affixed with rivets. the whole convertible conversion plug was installed as one assembly. you will probably have to cut into the interior sheet metal above the wheel house.
Old Aug 10, 2009 | 08:11 AM
Engine: ls1 soon
great... not what i wanted to hear but i guess it has to be done..
Old Aug 20, 2009 | 10:59 PM
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
I have a set in a 92 parts car if you need them I could cut them out (with the metal arround them) and then you could figure it out from there or you could come and get the remains of the car cheap, it is going to the schreader when I am done with it rear end is still in decient shape, it took a front end hit we are in kansas
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
TheExaminer
Sep 28, 2015 02:28 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
