Convertible Frame Issues
Old Jan 5, 2010 | 02:10 PM
Joeduren's Avatar
Anyone had the bolts for the convertible frame break behind the windows? I've got two broke and not sure what the best fix is. I can't find these parts anywhere. Only thing I know to do is drill it out and tap it for a slighly bigger bolt. Any ideas?
Old Jan 5, 2010 | 06:14 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Re: Convertible Frame Issues
If its the same one as I had go on mine I went to home depot and selected somethign which was similar...if I recall it was slightly longer and I just used a couple of washers as spacers, its not called a carage bolt but it looks similar but has a nylon sleve on it to allow it to pivot on the bolt.
It took a bit of searching but it worked out jsut fine for me. If you still have problems let me know and I will snap a quick photo to help out.
Dave
macertheracer's Avatar
Car: '91 RS CP now is the son's driver
Engine: CP =3.1, will get V-8 maybe someday
Transmission: stock
Axle/Gears: 3.42 posi W/ disks
check this out, they are called "SHOLDER BOLTS" we use them alot in aircraft machine tools http://www.fastenal.com/web/products.ex?N=999602314 you will have to measure the original to size it and these are grade 8 steel
Old Jan 5, 2010 | 07:26 PM
Joeduren's Avatar
Awesome! Ya'll rock. Thanks a bunch. That should take care of it
Old Jan 5, 2010 | 08:29 PM
Transmission: stock
no problem glad to help,
Old Jan 7, 2010 | 10:51 AM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Work for boeing huh? I use them here often enough.
Old Jan 7, 2010 | 11:42 AM
Transmission: stock
Spirit - Wichita
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Wylecoyote08
Nov 6, 2015 03:46 PM
dyeager535
Aug 28, 2015 08:10 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
