Convertibles with 5 speeds
Car: 88z
Transmission: t-5
I'm doing a little research on my car and was wondering if people with 5spd cars would post a pic of their RPO sticker?
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Convertibles with 5 speeds
Well . . . just for you . . .
Care to share the goal of the research?
Car: 88z
Transmission: t-5
Thank you sir. I was just curious to see the RPO codes on other 5 speed verts.
Here are some of the higlights of my car.
G92-AXLE REAR RATIO PERFORMANCE
GM3-AXLE REAR 3.45 RATIO
J65-BRAKE SYSTEM PWR, FRT & RR DISC
KC4-COOLING SYSTEM ENG OIL
MM5-MERCHANDISED TRANS MAN 5 SPD PROVISIONS
MK6-TRANSMISSION, MAN 5 SPD, BORG WARNER, 2.95 1ST , O/D
Axle/Gears: 3.08
One thing to keep an eye on is the year of the SPID's you may see here. They don't really allow for a truly direct comparison, but still interesting one. The verts changed over the years. Things like RPO's G92 and J65 were dropped from the IrocZ verts in '89, etc.
PS; nice ride.
PS; nice ride.
That's very kool! I didn't know you could ever have G92, 5 speed vert! Just for 87 and 88 I assume?
Anyone know how many 5 speeds were built in the years you could order G92 also?
Car: 1992 Z28 Convertible built 07/01/92
Transmission: 5 speed
Axle/Gears: 3.08
I'm looking for some help... I've got a fairly low mileage completely stock black '92 Z28 with factory 305/5 speed. I know there were 1254 verts for '92 but is there any place to get a specific breakdown of these? I've seen a half dozen or so RS's and only a couple Z's with 5 speeds and was looking for more info. Thanks!
Car: 1988 IROC Convertible
Transmission: 5 Speed
Axle/Gears: G92/3.45
I'm not aware of a breakdown on how many 5 speeds were made per year, but most cars sold as autos.
Even if you used 30% as the amount of 5 speeds made (which I think would probably be a little high) you only had around 376 5 speed verts made in 92.
Car: 1992 RS 'vert
Engine: 305 TBI
Transmission: MM5 5speed
Axle/Gears: 3:08
I went to the Compnine website vin decoder and came up with only 410 'verts with a 5 speed in '92 not sure about other years but would like to know
Axle/Gears: 3.08
Compnine??? Tell me more! This is the first time I've heard of it. Although I've owned several 3rd gen Z28's this is the first time I've really looked into production data and joined an online forum so you'll have to bear with my ignorance...
Car: 1992 RS 'vert
Engine: 305 TBI
Axle/Gears: 3:08
Try this website it worked for our '92 'vert, but not our '84 Cavalier 'vert.
http://www.compnine.com/vid.php
Car: 88 (SOLD) & 90 Iroc convertibles
Engine: 5.0 TPI, 5.0 TPI
Transmission: 5 speed & auto
Axle/Gears: 3.08 & 2.73
Just checked both my verts Canadian 88 IROC 5 speed,and US 90 IROC auto and was able to obtain the information for both.
Have been looking for a while for production numbers for the 5 speed thanks.
Axle/Gears: 3.08
I just checked my vin on compnine. According to the site there is only one other Camaro that was produced with the same options. I don't know how that realistically affects its value but it's nice to know! Thanks for your help!
1992 Trans Am
May 10, 2023 07:19 PM
