Serious 92 TA Vert leak
Old Jul 14, 2010 | 05:21 PM
bigbandwith's Avatar
I have a 92 TA vert and it has a serious leak. After a hard rain there is a puddle behind both rear seats. Problem is it is not coming from the top. I think it is coming from the toneau cover. Two questions: 1) Where do these things typically leak from, and 2) what trouble shooting methods have y'all used to find the leaks. Thx.
Old Jul 14, 2010 | 07:14 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: Serious 92 TA Vert leak
Are you sure it isnt coming in through the top? My car leaks worse than anything I have ever seen in the rain. It comes straight through the material, and around the windows, and probably the tonneau, too. Sit in the car and have someone spray it with the water hose, that should find it.
Old Jul 14, 2010 | 08:18 PM
injdinjn's Avatar
Car: 1986 Grand Prix TPI
Transmission: 200 4R
There is a seal that runs the perimeter of the tonneau cover. If the water fills or backs up the drain channel along the side of the car (the back it runs next to the decklid and down the taillight, the front has a hole and drain tube) then it will go into the car before it can go over the 1/4 panel. Clean the channel and drain hole, and make sure the seal actually seals... otherwise you'll have a wet floor.
Mark_ZZ3
May 24, 2018 01:02 PM
okfoz
Oct 13, 2015 02:19 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
