Problem with my convertible top
Old Sep 26, 2010 | 11:38 AM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Sometimes the rear of my convertible top pops up when Im driving down the road. What could cause this?
Old Sep 26, 2010 | 02:35 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
Re: Problem with my convertible top
Might be that it is not in securely. Try locking the rear and then lock the front at the windshield.
Old Sep 26, 2010 | 06:24 PM
tavert91's Avatar
Car: 91 Trans Am Convertible
Engine: LB9 5.0 TPI
Transmission: 5 SPD
Axle/Gears: Posi Rear
You might want to check that the hold down pin is engaging with the clip when you put the top up. Sometimes the slide (cable) stays in the open position when you put the top down and you need to push it back to the closed position before you put the top up. (and YANKEECARMAN is correct. Lock down the rear piece before you secure the front clamps.)
I always try to lift the rear after I secure the front before driving off. If I find it lifts, it is usually that the slide on the tonneau did not return to the locked position.
Old Sep 26, 2010 | 10:53 PM
Engine: 5.0 TBI
ok thanks guys for the advice
Old Sep 27, 2010 | 05:29 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Search and ye will find . . .
https://www.thirdgen.org/forums/conv...ps-poppin.html
Good luck.
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
