Trouble with top, won't go down!
Old Dec 6, 2010 | 03:29 PM
Texas T/A's Avatar
I've been trying to get this top down for the past hour. I think the glass window is too big. I just bought this car and this my first attempt to get the top to go down. Any videos,pics out there? What tops work best? I'm probably going to need a new top. Average cost installed?
Thanks for any input
Old Dec 6, 2010 | 03:35 PM
92FBirdVert's Avatar
Car: 1992 Pontiac Firebird Convertible
Engine: 5.0 TBI
Re: Trouble with top, won't go down!
well if your going to put a new top on it, you should get a plastic window. With your car being blue, I would go with a white top. As for the issues of getting your top to go down try laying your back seats down first.
Old Dec 6, 2010 | 07:09 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Make sure you fold down the front bow while trying to lay it flat.
Old Dec 6, 2010 | 08:12 PM
Engine: 5.0 TBI
yes make sure you do that atleast mine you have to
Old Dec 6, 2010 | 08:59 PM
Texas T/A's Avatar
Wish someone could post a viedeo of putting the top down. anyone have a cellphone w/ video? send it to my email
Old Dec 7, 2010 | 01:23 PM
bobbyk3lly's Avatar
Car: 1994 Camaro Z28 B4C T-tops,
Engine: LT1 350 5.7L 116K
Transmission: 4L60E (being rebuilt)
Axle/Gears: 3.23 Posi
if you still need help take a video of what yours is doing when you try to put the top down and send it to me and ill take a video of mine and show it to you...
Old Dec 7, 2010 | 03:25 PM
Texas T/A's Avatar
Took it to the shop, was told the top was installed bad. Needs replacing. I still want a video of someone putting the top down. Email it to me peteg67@yahoo.com
Old Dec 7, 2010 | 03:57 PM
Engine: 5.0 TBI
if your going to replace the top, go to third gen ranch and they have top frames for like $250 and tops are on ebay for $239
Old Dec 7, 2010 | 03:59 PM
Texas T/A's Avatar
Frame is good, guy quoted $1257 to install new top. w/glass
Old Dec 7, 2010 | 05:45 PM
Engine: 5.0 TBI
Holy ****! thats to expensive..... I would definetly try installing the top myself before I even thought about having it professionally done for that rediculously price. If it were me I would get a plastic back window....you dont have to worry about it shattering
Old Dec 7, 2010 | 06:11 PM
Guest
Guest
Posts: n/a
I dont know how a top "installed wrong" is going to cause your problems, and at $1257 to replace it...... sounds like a $1257 snow job to me.
Old Dec 7, 2010 | 07:46 PM
Engine: 5.0 TBI
heres the only video I found its about halfway through
http://www.youtube.com/watch?v=E6Z63CyMCrU
Old Dec 7, 2010 | 10:53 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
You say it has a glass window currently? So are you folding the rear seats down prior to attempting to put the top down? That could be your problem there. The glass window tops are awesome, a much better choice than plastic in my opinion. You just have to put the seats down WHILE you're moving the top up or down or it will put the glass in a bind.
Old Dec 7, 2010 | 11:00 PM
Texas T/A's Avatar
yes, I put the seats down. I can get the window to lay flat but its hard to get the rest of the top in there. Does the front fold twice?
Old Dec 9, 2010 | 06:31 AM
vthepooh's Avatar
Hope you figured out by now that these convertibles are NOT suppose to have Glass windows. Of course it wont go down the back needs to fold right in the middle. I have a 91 TA convert. Good luck! $1200 too much your getting abused.
Old Dec 9, 2010 | 06:35 AM
vthepooh's Avatar
About $500 for new top and $100 or so for install.
Old Dec 9, 2010 | 11:41 AM
Guest
Guest
Posts: n/a
Thats why the tops with the glass window are smaller windows that dont need to fold.
Old Dec 9, 2010 | 11:46 AM
Iroctopless's Avatar
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
That's a ridiculous statemant. Have you ever had any experience with a glass window rear top? If you had, you wouldn't be trying to mislead out members. There are tops such as the StayFast design that have glass and work well.
Readers, please try doing a simple forum search. You'll find tons of info to the contrary of the above quote. Here's a good place to start . . .
https://www.thirdgen.org/forums/conv...dow-glass.html
There's also some good advice as to how to lower a glass window top.
Good luck Texas T/A.
If somebody did replace an existing plastic window with one that's glass of the same size, then yes you would have issues. But none of the previous posts clarified that.
Old Dec 9, 2010 | 12:11 PM
BlueZee28's Avatar
If the shop says the top was installed incorrectly and that's why it won't go down, then why would you need to buy a new one? Just have them remove it an reinstall it the correct way.
And the statement about glass window tops not working is completely false. If they didn't work, nobody would make them and nobody would be buying them like myself an others have. I LOVE mine. And if for some reason by accident I have to replace mine again it will be another glass widow top.
Old Dec 9, 2010 | 10:16 PM
Texas T/A's Avatar
Let me clear this up.The owner of the shop said it was done incorrectly because of how much material was cut and glued under bow#5 (too short and has come apart on the pass side) The window does lay down but is really a tight fit. The rest of the top doesn't lay flat enough to close the cover. I looked today and the top is a EZon top w/glass window. I've already ripped the cloth on one of the seatbelt towers trying to get this top down. I guess it will have to be a plastic window top that will make it work in my case. I'm sure others have used glass window top because I've seen them.
Old Dec 10, 2010 | 12:19 PM
BlueZee28's Avatar
Get a top from topsonline.com, they sell plastic and glass. The glass is only $40 more i think. Just go with their top and you'll be happy I gaurantee it. Their glass window tops are top notch. Make sure to order the stayfast top.
Old Dec 10, 2010 | 06:39 PM
Texas T/A's Avatar
Do you guys not read? I said it was a EZon top w/glass.
it's the same top "topsonline" sells
Old Dec 10, 2010 | 07:05 PM
Can you take a picture of the top as far down as you can get it and post it up? The PO of my vert didnt know how to put it down and the way he showed me to do it caused it not to lay down all the way, and I had to figure it out myself.
Old Dec 10, 2010 | 07:20 PM
Engine: 5.0 TBI
then buy it
Old Dec 10, 2010 | 07:23 PM
Texas T/A's Avatar
No, what I'm saying is that I already have the top everyone is recommending and it does'nt work. I'm going to get the Robbins plastic top and be done with it.
Old Dec 10, 2010 | 07:26 PM
Engine: 5.0 TBI
so are you going to get a new convertible top frame to?
Old Dec 10, 2010 | 07:28 PM
Texas T/A's Avatar
not for this car.I think the top is still in good shape. I'm asking around for a frame for the other 92 TA I have.
Old Dec 10, 2010 | 07:30 PM
Engine: 5.0 TBI
third gen ranch has one for $300
Old Dec 10, 2010 | 08:18 PM
Texas T/A's Avatar
that's cool. I'm waiting on a forum member to give me a price on one that he has.
Old Dec 10, 2010 | 10:04 PM
Guest
Guest
Posts: n/a
I'd be surprised if a new top solved your problems. Where it is installed should not matter when its down, the canvas is not tight when its in the well. If something is bent or missing or whatever on the frame itself, then the top may not collapse correctly and you will not be able to close the cover.
I have not heard of a single person having an issue with a glass window top on these cars. Not one. I think if you go the route of replacing it to solve a problem that likely does not exist, you'll still have a problem.
Old Dec 10, 2010 | 10:10 PM
Texas T/A's Avatar
Good point, but I see nothing wrong with the frame. it looks to be all there. The glass barely fits when laid flat in the rear. The rest of the top folds down but kinda bunches up and doesn't lay completely flat. The shop I took it to never tried to lower the top. I'm thinking about getting a second opinion.
Old Dec 11, 2010 | 06:29 PM
Talon's Avatar
What year of a car is this,???
Old Dec 11, 2010 | 09:43 PM
Texas T/A's Avatar
1992 TRANS AM
Old Dec 11, 2010 | 11:54 PM
BlueZee28's Avatar
Ok then your problem definitely isn't the top. Nobody, NOBODY, has ever had a problem with this top not being able to fold down. If it's because someone cut it too short in the front during installation, that's no fault of the manufacturer. If you're going to buy a new one anyways, why not get the glass one again and actually have someone that knows what they are doing install it?
Old Dec 16, 2010 | 04:39 PM
TX T/A's Avatar
Car: 1992 Trans Am Conv.
Found out what was wrong with my top. It turns out the previous owner bent the rods that help fold the top that last time so it tucks in flat. I'm still going to replace that top with a new one. If anyone wants to buy this top LMK. It looks new still just was installed wrong,wrong glue was used to. Im sure it can be reused
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
theurge
Aug 21, 2015 12:46 PM
djmarch
Aug 19, 2015 12:07 PM
EFR2000
Aug 18, 2015 08:54 PM
