want to add power antenna,whats needed?
Old Jan 24, 2011 | 06:23 PM
Texas T/A's Avatar
want a factory power antenna on my convertible, what parts do I need to get it done?
Old Jan 26, 2011 | 09:48 PM
chris schaner's Avatar
Car: 1990 irocz camaro
Engine: 350 tpi
Transmission: auto
Axle/Gears: 3.42 posi disc 10 bolt
Re: want to add power antenna,whats needed?
82-92 gm power anntanna the bezel for the fender and the wire harness that was made for those years and the power reley inside under the pass side .easy done mine looks and works great and is stock
Old Jan 26, 2011 | 10:15 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
All you need is the antenna and the relay, and 3 wires:
12V battery, 12V trigger signal from radio (or a manual switch if you prefer), and ground.
Old Jan 27, 2011 | 07:55 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
If you find a Pwr antenna car, get the pices off of that.
The Relay is under the RH side of the dash...
From what i remember ( it has been a while )
IN to Relay
Pink goes from Radio to relay
Orange from Battery
Ground
OUT to Antenna
Black
Orange
Green
There has to be 3 wires to the antenna, one for ground, one to make it go up, and a third to make it go down.
John
Old Jan 29, 2011 | 11:07 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
IN to Relay
Orange from Battery
Ground
OUT to Antenna
Black White
Orange Grey
Green
John
The special relay reverses the + and - on the green wire so the motor can run both ways (up and down).
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Aug 8, 2015 03:15 PM
