how to test the electrical connectors for tonneau cover?
Car: 1989 IrocZ Convertable
Engine: 350 5.7
Transmission: AUTO 4 SPD, THM 700 R4
Axle/Gears: AXLE REAR, 2.73 RATIO
i get no clicking from my tonneau cover switch in center console. I worked up to a few days ago. I checked my fuse box and all fuses seem to be good. Is there a way to test the electric connectors in the trunk that tell the latch that the trunk is closed? i wonder if that is not working any more, i don't know what else to try. searched forums but did not find what i think i am looking for. I can only open it with the manual pull cords now.
Car: 91 Firebird
Engine: 6.0
Re: how to test the electrical connectors for tonneau cover?
Its a ground circuit, so start by checking the grounds under the center console and that the solenoid poppers havent' gotten wet or rusty.
Engine: 350 5.7
so i will try to disassemble the center sole to look at the grounds on the switch. Also where are the solenoids, are the in the back somewhere?
thanks.
thanks.
Car: 91 Firebird
Engine: 6.0
follow the cables you are pulling on to release the tonneau.... they are attached to the solenoids
*also*
the wiring also passes through the trunk pull down switch. So if you're pull down isn't working right, I'd start digging there
*also*
What is the condition of your trunk (hatch) pull-down unit. If that is not operating correctly your tonneau will not release. It is a safety feature since the tonneau and trunk deck lid occupy the same space when opened. Fix the problems with your trunk pull-down uniit and your tonneau release should work again.
Lon
Lon
Engine: 350 5.7
Lon
Lon
1992 Trans Am
05-10-2023 07:19 PM
ambainb
04-25-2016 09:21 PM
eightsixseven
08-14-2015 03:09 PM
