Is there anyway to pretreat a plastic Window to last longer?
Old Jul 25, 2011 | 05:28 PM
92BlueRS's Avatar
I just finished installing a new top on my 92 RS Convertible and would like to find if you guys know of any treatments that can be applied to the window to make it last longer. The original one turned reddish brown and eventually broke and I'd like to know if there is anyway of prolonging my new tops life. Thanks
Old Jul 25, 2011 | 07:24 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Is there anyway to pretreat a plastic Window to last longer?
I don't know about prolonging it (I don't have a convertible). However once my neighbor borrowed my 'Plastic X' (which I used for polishing lights and gauges) for his Mercedes plastic window convertible, he uses it faithfully. http://meguiarsdirect.com/detail/MEG%2BG12310
Old Jul 26, 2011 | 05:18 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I went with a glass rear window this time, it was more expensive but I will be able to tint it and it will last as long as the top does. The only bad thing is you have to be gentle folding the top down.
Old Jul 28, 2011 | 03:48 PM
RagRoc's Avatar
Car: 88 IROC Convertible
Transmission: M5
Axle/Gears: 9-bolt 3.45
I bought this plastic cleaner for my motorcycle windshield, and after reading the instructions, I tried it on the plastic back window. This stuff is incredible!!!
http://www.plexusplasticcleaner.com/plexus.html
Old Aug 5, 2011 | 11:14 AM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
this surprises me.my plastic is still pretty clear.the problem i have is the thread rotted away at the bottom and it seperated.
Old Sep 6, 2011 | 01:51 AM
92BlueRS's Avatar
Thanks guys as far as the glass window goes I considered it but the risk of breaking it and the smaller size window we decided to stay with the plastic. Ragroc thanks for the suggestion on the plexus I have a atv and motorcycle shop and I never thought of using the plexus on conv window. I'll order some and see how it works.
Old Sep 6, 2011 | 01:58 AM
92BlueRS's Avatar
Yeah the window totally went bad. I've seen others with bad windows too. The stitching was rotted too but not coming apart yet. Maybe its the sun it started in oregon then we moved to arizona and it only got worse. It's too bad chevy didn't design a glass window in the top in the first place.
Old Sep 6, 2011 | 09:12 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
UV rays break down plastic, wax it often for protection.
Old Sep 6, 2011 | 11:55 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Yes, the number one product to protect the rear plastic window from UV is called a garage. The number two product is called a car cover.
Lon
Twin_Turbo
Mar 14, 2016 10:10 PM
gteatr6
Interior Parts Wanted
Sep 10, 2015 09:55 PM
Fronzizzle
Sep 8, 2015 12:10 PM
scottmoyer
Sep 7, 2015 07:06 PM
90formulaVortec
Sep 3, 2015 09:26 AM
