trunk carpet replacement
Old Feb 2, 2012 | 09:52 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I am just completing installing new carpet in the passenger area and am now moving on the the trunk to replace that carpet. I have the carpet already purchased from stock interiors and upon initial eyeballing...am uncertain if it has to be cut around the trunk hinges. Any insight into getting that in efficiently would be appreciated. Car is 88 IROC. thanks
Old Feb 2, 2012 | 10:12 AM
Emtp99's Avatar
Re: trunk carpet replacement
If I may ask where did ya find the carpet? Was it molded.? How tough was it to replace? Etc as you can guess I'm about to take on the challenge of cleaning up my 91 vert after my kid tore it up for 5 years. Seats dashboard carpets paint etc.
Old Feb 2, 2012 | 10:16 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Carpet came from www.stockinteriors.com . The pass area was more challenging than I had initially anticipated because the entire center console needed to be removed. On top of that there is a fair amount of trimming to do as well. The carpet is molded but even than fit was okay. The carpet needs to be worked over and pressed pretty good to seat right, but I am sure with time it will settle even better. I did install sound deadening material under it as well.
Old Feb 2, 2012 | 10:21 AM
Emtp99's Avatar
Thanks for the quick reply I have been looking at jc Whitney but I will check out the link you sent
Old Feb 2, 2012 | 06:38 PM
zenish's Avatar
Car: 1989 camaro rs convertable
Engine: 305 tbi
Axle/Gears: 7.5"3.42 gears forth gen 2000 camar
i put a coupe carpet in my car and had to trim it around the added convert parts for the trunk.use your old carpet as a pattern.
Old Feb 2, 2012 | 07:45 PM
botch1's Avatar
Car: 1990 Iroc Z Red Vert
Axle/Gears: Stock
I have installed carpet in 4 camaros in the last 2 years. The best way in install is STEAM the carpet first to get out some of the wrinkles. Start around the console,toward the under dash area,sides to door openings then toward the rear.Take a metal pointer (all) and heat is up with a bottle torch and poke it through the carpet for your seat belt holes. It melts a nice hole for the belt bolts and seat frame bolts.Hope this helps.JIM
Old Feb 22, 2012 | 06:58 AM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
Trunk carpet was a snap. Did everything recommended above. I was amazed at how heavy duty the OEM carpet was. The backing was incredibly thick. The hot poker for the seat belt holes and seat bolts worked very well.
Old Jun 19, 2012 | 10:52 PM
twistedfaith17's Avatar
Car: 92 rs
Engine: 350 tbi
Transmission: 700-r4 with shift kit
was curious if you bought the one with the console area cut out, or not...if so how much is cut out...either way what would you or anyone who would like to answer suggest
Old Jun 20, 2012 | 02:28 PM
rubyred88's Avatar
Car: 88IROC Vert
Engine: ZZ383
I bought the one with the console cutout. I cant quite recall how much is cut out. I did have to snip the end to get it started up against the firewall.
Old Aug 16, 2012 | 02:48 AM
Elizabeth2's Avatar
Hi guys there is no doubt that carpet's become essential need of every house and offices and hotel's but they also faced a problem of it's cleaning all carpet's felt dirty after sometimes and need to it's cleaning and replacement replacement is better option than cleaning in this way new carpet's bring and decorate our house or office and give a new look..
Vintageracer
Jan 10, 2020 05:33 PM
lee01
Apr 9, 2016 01:56 PM
Reddeath210
Oct 6, 2015 08:20 AM
AmorgetRS
Convertibles
Aug 31, 2015 11:55 AM
