Another convertible spoiler question??
Old Jun 10, 2012 | 09:47 PM
GoingForSix's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305 TBI
I have a 91 RS Convertible 5.0L V-8I picked up cheap. It has issues, but was too cheap to pass up. Of course I have more projects then I now what to do with, but always wanted a convertible. Loved the 3rd gens...
The center section of the spoiler is kind of damaged. Mounting studs broken etc. The molded sides are fine and intact. I know the vert spoiler is different on the sides. Is th center section the same as any of the other 3rd gen spoilers, or is the whole thing different?
Old Jun 11, 2012 | 02:18 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
Re: Another convertible spoiler question??
pretty sure its unique to the vert.
Old Jun 11, 2012 | 07:46 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Its vert specific. Ive fixed a few with broke studs. 3m panel bond and new stainless studs. Its not hard to do if you can with with epoxies.
Old Jun 12, 2012 | 06:34 PM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
I did the same, I took solid plastic dowels and cut them to size and panel-bonded them in, when dry drilled them out and added the new studs.
Old Jun 13, 2012 | 01:13 AM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
I took my factory plastic pedatsals and a grinder and ground a lot of slits all around the plastic so the epoxy would have something to grab. I then took 2" PVC water pipe and ground it to fit around the plastic pedastal with the correct angle to help it seat on the trunk lid for extra support. I have pulled very hard trying to get it to turn loose and it stays solidly attatched.
Old Jun 19, 2012 | 10:35 AM
Engine: 305 TBI
Thanks for all the replies. I assume that was the case. I will have to work on repairing mine. I was just hoping maybe GM was smart and used possibly the center section from an earlier 3rt gen model. Had seen a few in local junk yard.
Old Jun 19, 2012 | 06:43 PM
Tinbender59's Avatar
Car: 1997 K1500 SS/SB
Engine: LT1 with TPI on top
Transmission: 4L60E/np241,
the Verts were not built by GM, ASC built most of them, so they were the ones that should have made extras for the parts department, but as with any 3rd party it is all about money. I believe some of the third brake lights are actually ford units - LOL dang ford anyway.
Frozer!!!
Jan 19, 2024 04:55 PM
69 Six Pack
Oct 5, 2015 07:51 PM
wbrooks63
Exterior Parts Wanted
Oct 4, 2015 08:40 PM
Fronzizzle
Aug 19, 2015 01:36 PM
redmaroz
Aug 16, 2015 11:40 PM
