Convertible rear window is cloudy.
Old Oct 12, 2012 | 01:50 PM
JOEM's Avatar
Car: 1992 Z28 Convertible
Engine: 5.0 TPI
Axle/Gears: 2:73 L/S
The original back window is cloudy. Do I need to just change it or is there a way I can clear up? Any suggestions or products?
Old Oct 12, 2012 | 06:13 PM
BADNBLK's Avatar
COTM Editor
Re: Convertible rear window is cloudy.
Anything that will polish paint will polish plastic. I know that there is specific products out there for plastic headlight lense and stuff, and they may work better. You might break out some of your polish and try and small spot to see what happens. Make sure whatever you do to mask off the canvas... with my new top on I find that anything that touches it will leave a mark. I'm sure most would come off, but masking would be easier.
POST YOUR RESULTS!!!
Old Oct 12, 2012 | 09:37 PM
JOEM's Avatar
Engine: 5.0 TPI
We are on the same page. I was thinking of the headlight polish I have. I was also thinking of trying Rainx over that. Any other input out there
Old Oct 12, 2012 | 10:00 PM
majobis's Avatar
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
My neighbor has had good luck using 'plasticx'.
http://www.walmart.com/ip/Meguiar-s-...olish/16550253
Old Oct 13, 2012 | 10:56 PM
abray1's Avatar
Car: 90 IROC 2-92 Zs blk vert & prpl
Engine: stealth ram brodix track 1 ful port
Transmission: 700r4 4l80e
Axle/Gears: iroc 375 lokr 92 Z 277 pos vert 327
Flitz will polish it back clear. Flitz will also make cds play that skip as well as polish metal. Oh, and don't change it out. Leave that car all original and perfect.
Old Oct 15, 2012 | 08:45 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Just an FYI out there for all of us convertible owners... I would not recommend using ammonia based cleaners on the plastic rear window... Many plastics, ammonia attacks it and clouds it... The window I believe is made from Vinyl...
John
jaridjohn
Jul 8, 2024 03:49 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Dialed_In
Aug 20, 2015 01:45 PM
