Door rattles
Old Apr 11, 2015 | 11:24 PM
calidude's Avatar
Car: 1985 Camaro IROC
Transmission: Auto O/D
Door rattles
Hey guys my 1990 seems to have all kinds of rattles and the doors seem like they are loose as if not closed properly.
Any suggestion?
Old Apr 12, 2015 | 11:22 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Door rattles
There is a lengthy thread on that very topic that has lots of good info. I suggest you familiarize yourself with the Search function.
Old Apr 12, 2015 | 12:22 PM
calidude's Avatar
Re: Door rattles
Hmm, I did and didn't see one specifically for convertibles. If you would be so kind as to paste a link I would appreciate it.
Old Apr 12, 2015 | 04:54 PM
Re: Door rattles
Doors are doors. There is no difference between hardtop, t-top, or convertible doors. Did a quick search for your thread title, "Door rattles" and here you go:
https://www.thirdgen.org/forums/body...servation.html
Old Apr 12, 2015 | 10:59 PM
calidude's Avatar
Re: Door rattles
Thanks for the link....
hmm, not according to this post and it's what I was looking for as mine seems to be missing the wedges although I see 2 holes for them.
Re: Window/Door Rattles--Observation and Pics
Quote:
Originally Posted by fyrebird68 View Post
They create a tight fit between the closed door and the B pillar to reduce flex front-to-rear. I think they appear only on T-top cars.
Correct the Door wedges are for T-top and Convertible models. It transfers the load from the bottom of the car to higher on the doors to reduce body flex. If you remove them on a T-top or Convertible your door jams will get beat to crap, I am not sure anything good would come of it. One time I did not have my drivers door all the way closed and I could really hear the door beating and feel the car flexing as I drove down the road. I want to put them on a hardtop personally.
John
Old Apr 13, 2015 | 09:27 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Door rattles
Throw some new door/window seals on it........you'd be amazed what rattles disappear.
Old Apr 13, 2015 | 12:07 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
Re: Door rattles
The Wedges will help too... someone might have taken them out because they were binding... But you can get them from any 82-92 T-top or Convertible in the junkyard... Some places might not even charge you...
There are spacers too... get those... You might have to get a couple to get enough spacers.
Old Apr 14, 2015 | 10:49 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Door rattles
A big problem with these is the rubber stopper on the bottom of the window metal frame rots off and allows the window to go to far down and out of the upper felts..
I just replaced the rubber stopper on my 89 vert.
Old May 16, 2015 | 11:18 PM
calidude's Avatar
Re: Door rattles
Replaced the door seals and bumpers on the outside of the doors from replacements from Hawks, huge improvement!!
Also dug into the inner window bumper at the bottom and they were gone and in chunks in the door. Drilled out the rivets holding them on. Ordered those as they are on the way along with a window felt bracket as one on the drivers door is missing it. Also a new handle as the drivers door one rattles when you close it.
Thanks for the help guys
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
jrdturbo
Mar 31, 2016 02:58 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
Eric-86sc
Sep 28, 2015 11:37 AM
