Are convertible trunk lid pulldowns and latch the same as the hatchbacks?
Old Mar 7, 2017 | 08:04 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
I would think so but maybe not?
Old Mar 8, 2017 | 08:08 AM
rarebmx's Avatar
Car: 89 IROC/89 Vert/87 Vert/89 GTA Vert
Engine: 5.7/5.0/5.0/5.7
Axle/Gears: 9" 2.77/9" 3:23/9" 3:42
Re: Are convertible trunk lid pulldowns and latch the same as the hatchbacks?
Same.
Old Mar 8, 2017 | 12:48 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Very late 92 verts don't have a pull down type, they used a slam style.
Old Mar 8, 2017 | 07:24 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
year for year they are the same AFAIK. The 87-90 are the large type, and then somewhere in 1991 or 92 there was a smaller pull-down assy to accomodate the slam style. I accidentally pulled a 92 style pull-down and the mounting was way way different than my 87
Old Mar 8, 2017 | 09:37 PM
my82roc's Avatar
Car: 89 Iroc Convertible
I have a 92 vert slam assembly.If I were to switch the latch on the trunk lid would that work on my 89 vert?If so does the plunger switch that prevents the tonneau and trunk from opening at the same time still have a place in this setup?
Old Mar 10, 2017 | 10:50 AM
okfoz's Avatar
The welded brackets for the large pulldown is completely different than the slam version. You could swap them out, but you would have to remove the existing brackets and then weld in brackets from a later car.
Old Mar 10, 2017 | 10:53 AM
my82roc's Avatar
That's true...I didn't even think of that
Old Mar 10, 2017 | 11:02 AM
Engine: 350 TPI L98
Transmission: WC T5
For the pulldowns, they are the same. I got into mine yesterday. All it needs is a new housing and guides.
Old Mar 10, 2017 | 12:09 PM
okfoz's Avatar
Here is a little history
Latch 1 - Slam style 1982-1985
Pulldown style 1 - 1986 thru 1991 sn 240931 (Firebird) & 173201 (Camaro)
Pulldown style 2 - 91 (240932 & UP - Firebird) (173202 & UP - Camaro) & 1992
The slam style for the Convertible started at 240932/173202 as well
Hope this helps
Old Mar 10, 2017 | 12:36 PM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
Guts for the pull down motors are plentiful and cheap at Junkyards. Just find full-size Buick and Cadillac trunk pull downs. Mine has parts from a Deville in it, working perfectly for over a year now of almost daily use.
Old Mar 10, 2017 | 12:57 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
I sold a slam style off of a '92 vert on this board not too long ago...;
Old Mar 11, 2017 | 12:50 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Correct for 86- early 91 convertibles and coupes. Mid 91 the pull-down unit for the coupes changed to a completely different type. The gear nut, wave washer and bearing were the only parts that carried over from the prior design. For the mid 91 convertinles they seitched to a slam latch for the trunk.
Lon Salgren
Top-Down Solutions
Old Mar 14, 2017 | 01:33 AM
1992 Trans Am's Avatar
Car: 1992 Pontiac Trans Am Convertible
Engine: 5.0L 305ci TPI
Transmission: 5 Speed Manual, World Class T-5
Axle/Gears: 3.08
My 92 TA vert was manufactured in January 1992 and has the slam type trunk latch.
claytonjn
Jun 13, 2016 06:04 PM
Jk_Under
Apr 6, 2014 09:52 AM
LastKnownOne
Sep 24, 2012 05:09 PM
87firebird305V8
Oct 17, 2009 01:18 PM
khellendros
Jun 1, 2002 11:11 PM
