89 Camaro Convertible....
Old Nov 11, 2017 | 10:53 PM
elektrik's Avatar
Hi all! I just picked up an 89 Camaro with 72k original miles (yes I actually believe it). The car is in pretty incredible shape, minus a high idle (I have to follow the thread to work on changing it) and a convertible top that has the seals missing...
but the top has one more problem thats driving me crazy (I don't have much experience with verts in general so bear with me)... The passenger side seems to be offset backwards by about an inch...to the point that the hinge to hold it on in the front doesn't 'grab'..I'm going to try to take it apart tomorrow, weather permitting, but I'd like some feedback on how to make things easier on me.
Old Nov 13, 2017 | 12:57 AM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
Re: 89 Camaro Convertible....
Congrats on the Vert!
Thirdgen verts are some of the nicest looking cars IMO.. the lines are amazing..
I’m sure you’ll figure out the Idle.. throttle position sensor or whatever it may be..
For the top latch.. 89 is different than mine so I don’t have experience with how those latch.. if mine wasn’t lining up I’d look at the header and take the trim off and see if anyone rigged anything back together that isn’t lining up right and try to get it right.. at least for 89s they make a lot of aftermarket Vert parts..
Congrats and good luck!
Old Nov 13, 2017 | 10:42 AM
elektrik's Avatar
Good to know. Thanks!! I love this car already, and I've only owned it for 3 days lol!!
P.S. WHERE can I find all those aftermarket convertible parts? I can only seem to find the top, not any of the linkage parts if I need them.
Old Nov 13, 2017 | 10:58 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Welcome and congrats! One of the best places to start is http://top-downsolutions.com/
Old Nov 13, 2017 | 02:37 PM
elektrik's Avatar
Thanks!
Old Nov 13, 2017 | 09:23 PM
Axle/Gears: G80 GU2
Hawks has some parts too..
http://www.hawksmotorsports.com/sear...rtible&Search=
Can always check out eBay and people that are parting out convertibles are around..
Old Nov 14, 2017 | 03:27 AM
ROCFATHER's Avatar
Car: 89 IROC-VERT
Engine: TPI 305
Transmission: 700R4 Auto
Axle/Gears: 2.77
Any more pics of the actual car??
Old Nov 14, 2017 | 08:16 AM
elektrik's Avatar
yup. I posted in this topic :-)
https://www.thirdgen.org/forums/conv...ml#post6182901
elektrik's Avatar
Thanks for the info 88.
Old Nov 15, 2017 | 08:01 AM
elektrik's Avatar
Welp, the High idle's fixed thanks to the good folks here at thirdgen and their abundance of information. Now it's on to a front end alignment and door/trunk locks..anyone recommend a good vendor for those?
Old Nov 16, 2017 | 09:00 AM
elektrik's Avatar
and now the alignment is fixed..just have to fix a bit of slop in the steering box and get the tires balanced (there's a bit of bouncing going on the freeway)
