Convertible top parts needed to bring top down
Old 03-18-2018, 05:20 PM
Desertvert87's Avatar
Just purchased an 87 gta very missing all the parts to bring down top into cover where can I get them
Old 03-19-2018, 11:37 AM
FART_NUGGETS's Avatar
Car: 1989 Iroc-Z Convertible
Axle/Gears: 2.73:1
Re: Convertible top parts needed to bring top down
What parts exactly? The top and tonneau (cover) are both manually operated.
-Unlatch from the front header (two manual latches)
-release rear bow from the tonneau (handle on the inner driver side of the tonneau)
-then lift the back of the top straight up
-open tonneau (center switch in center console)
-lower the back of the top into the well
-fold the front of the top back
-lower the tonneau back down.
Old 03-19-2018, 11:46 AM
88IROCvertZ's Avatar
Car: 1988 IROC Z Convertible
Engine: 305 TPI (LB9)
Transmission: 700 R4
Axle/Gears: G80 GU2
I looked at this and was confused myself.. There are members on here that sell used convertible parts.. you could probably find what you need if you can narrow down the parts you need..
Many of these cars have tonneau release issues but usually the top frame holds up pretty good..
Old 03-19-2018, 02:30 PM
There is no release inside car it has all been taken out
Old 03-19-2018, 02:37 PM
Axle/Gears: G80 GU2
So you need the slider and rod assembly to pop the rear of the top up? If you pull the rear seat down you can manually pop the top and pull the back window up. You should then be able to pop the tonneau and unlatch and lower the top.. If the tonneau doesn’t pop from the switch there is a manual way to pop that as well, but I’ve never had to deal with that..
So it’s a tonneau issue and not a top issue?
Old 03-19-2018, 02:40 PM
Exactly I'm able to move the top forward as manually from the back but the tonneau is locked down so yes I need the assembly to release it
Old 03-19-2018, 03:24 PM
Axle/Gears: G80 GU2
Check this Thread out.. good info here..
https://www.thirdgen.org/forums/conv...eau-cover.html
Old 03-19-2018, 06:11 PM
Thanks so much found the manual release cables.
Old 03-19-2018, 06:36 PM
Axle/Gears: G80 GU2
Good stuff! Hope you get it working properly but at least you can operate the top!
Old 03-19-2018, 06:40 PM
Old 03-20-2018, 06:47 AM
Axle/Gears: 2.73:1
I just got your PM, but it sounds like you have it figured out.
Old 03-25-2018, 09:42 PM
Goodolboy0404's Avatar
Car: 1987 Camaro IROC-Z w/ T-Tops
Transmission: Automatic
Axle/Gears: Factory 9 bolt w/ 2.77 ratio
I bought a 89 IROC at an auction and trying to get it halfway decent to store until I have time to restore it. Does anyone know where to get this? Both the driver and passenger side or busted. Is this common on these cars? has anyone had these welded back together by chance?
wildstar
07-28-2014 01:38 PM
JerseyMark
09-14-2004 10:52 PM
smiley23
07-14-2003 12:43 PM
CAMARO82
06-05-2002 06:22 AM
85F-body
01-03-2001 01:01 PM
Quick Reply: Convertible top parts needed to bring top down
