Top options - lined with glass?
Old Jan 15, 2019 | 08:37 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Does anyone make a lined (double layer top) with a glass window?
Old Jan 15, 2019 | 09:17 AM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Top options - lined with glass?
Check with topdownsolutions.com if anyone knows he would.
Old Jan 15, 2019 | 04:13 PM
Engine: 350 TPI L98
Transmission: WC T5
Called topdown, he said to call topsonline. They said I would need to replace my 89 frame with a 90-93 frame to be able to run a headliner
I wonder if the headliner improves the insulation and sound reduction much/
Old Jan 15, 2019 | 06:08 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
The headliner used is a two parter.It mostly hides the frame work, seems like.I dont think its wraps around the window completely and its made for the plastic window w/ the glass version being much smaller.I would guess there'd be a (larger) gap between the HL/window, but then again maybe topsonline could make you one to fit.Since the offer the glass window as an option.I cant imagine it offers much insulation/noise reduction.It fits kinda loose.Nothing like the HT liners, but ive only seen a couple of them though.
I have one i pulled from a wrecked one, supposedly an 89, but i never verified.Regardless, ima try to fit it to my 89 when i get a new top.It attaches just below the rr window/sail panel with a small bolt already on the frame per side, plus under the verticle seal at the rear of the door window.Then also at the very front under a flat bar with some 12 screws or so.So i dont see why one couldnt make it fit earlier frames, but who knows.TOL sells them for $160, take a gamble.Im too cheap to try.
Old Apr 26, 2019 | 06:50 PM
M3638's Avatar
Car: 1990 Iroc Convertible
Like this one? 1990 Iroc Convertible w/glass.
Does anyone make a lined (double layer top) with a glass window? What is a double layer top?
Old Apr 28, 2019 | 02:35 AM
ThePain's Avatar
Car: 1992 RS
Transmission: Automatic
Ohhh.... that's sexy. I can't wait to finally get a new top for mine.
Old Apr 28, 2019 | 07:37 AM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
My 91 has a headliner and I don't think it helps with noise at all. It does do a nice job of hiding the frame though. It probably insulates a tad, any time you have a air gap between it will have some insulation quality.
Old Apr 28, 2019 | 10:49 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
90-93. Isnt 93 4th gen?
Veaceonee
Jan 19, 2013 10:19 PM
Mohammed
Theoretical and Street Racing
Apr 28, 2002 03:29 AM
CobraKiller
16
Apr 9, 2002 07:01 AM
Greg Kuhlmann
29
Apr 2, 2002 06:34 PM
bigals87z28
16
Mar 7, 2002 06:46 PM
