Trunk motor on 91-92?
Old Feb 21, 2019 | 09:40 AM
Paintchips97's Avatar
Car: '84 TA, '88-89 GTA convertibles
Engine: 406ci SBC, LB9, L98
Transmission: T56, 700r4s
Axle/Gears: 3.73 10 bolt, 3.27 9 bolts
I have a ‘91 TA vert, and me and another guy were wondering if anyone had added a trunk pull down motor to these cars. Also if anyone had added a stronger strut or anything to “pop” the trunk when the key is turned, since it’s a pain sometimes to open when your hands are full. Anyone done any trunk mods to these cars?
Old Feb 21, 2019 | 02:07 PM
Drew's Avatar
Re: Trunk motor on 91-92?
Sounds like you have a later 91. Because early 91 convertibles have the pulldown assembly like a regular hatchback. As far as converting from one to the other, you're on your own there.
Old Feb 22, 2019 | 06:40 PM
yankeecarman's Avatar
Car: 1991 Trans Am convertible
[/QUOTE]
My 91 doesnt even have the pull down. Maybe it was changed before I got it although it was a one owner car before I bought it.
Old Feb 23, 2019 | 10:12 PM
okfoz's Avatar
Engine: 5.1L TPI, 5.0L TPI
Transmission: 700R4, M5
IIRC The later 91-92 pull downs used the same mounting points as the non pull down from 1982-85 or 86, the pulldowns from 87-90 are huge in comparison...
John
Old Feb 27, 2019 | 04:11 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I bought a pulldown motor for mine YEARS ago, mounted it up, and saw the proper connector was back there so I plugged it in. The tonneau release solenoids started clicking like crazy. I guessed that, at least for my car, ASC pulled power for the solenoids from the trunk release switch circuit or something. I put the factory latch back in and the motor has been sitting on a shelf for almost a decade.
yusky03
Sep 6, 2012 10:17 PM
jimp2001
Feb 19, 2006 12:56 AM
90vertcamaro
Car Audio
May 10, 2004 09:44 PM
88305tpiT/A
Aftermarket Product Review
Nov 6, 2001 10:32 AM
86NiteRider
May 4, 2001 03:59 PM
