Took the plunge
Old May 13, 2020 | 09:31 AM
Tootie Pang's Avatar
Car: 1989 IROC Convertible
Engine: 350 TPI L98
Transmission: WC T5
Took the plunge
Bit the bullet and dropped $1800 on a new top install. Ugh. Oh well, the car will be that much more complete. The existing top looked great but had shrunk and apparently was no longer save-able.
Old May 13, 2020 | 09:47 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
Re: Took the plunge
if you can get the old top. I need one for measurement purposes.
let me know.
Thanks,
Chris
Old May 13, 2020 | 10:07 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Took the plunge
No idea if that price is in-line or not, but years ago, I helped my late older brother install a new convertible top on the '67 Corvette roadster he was frame-off restoring. And while he was an extreme perfectionist, I was still very surprised at all the measuring/fitting/re-measuring/re-fitting/fiddling involved in getting the top to fit correctly and look just-right; certainly not a job for the average do-it-yourselfer.
Old May 13, 2020 | 10:36 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
Re: Took the plunge
If that's for the top and the install, i'd say it's on the low side.....
Old May 13, 2020 | 12:47 PM
Engine: 350 TPI L98
Transmission: WC T5
Re: Took the plunge
Top and install. Glass window and reputable shop. It sounded high to me too. I found the tops for $800. $1,000 to install but I do know it is not a typical DIY job.
Chris84TA, I will ask to retain the old top FYI.
Old May 13, 2020 | 01:52 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Took the plunge
Are you happy w/ the job? I see a lot of 3Rd gen F Bodies have tops pulling up where the rear bow meets the body. How is yours? What, if any, other parts were replaced w/ the top? IE Weatherstrip. Did the frame need painting? My 89 needs a top and I am considering doing it myself, w/ a helper (wife). Approx. $1000 labor, two guy, 8 hours, I suppose? Not too bad for cali. Photos would be nice.
Chris 84TA's Avatar
Engine: 355
Transmission: WCT5
Re: Took the plunge
Thanks, I am hoping that just a few mods will make it fit my 84, but don't wanna drop full price for an experiment. If it works, I will purchase a new one to do the final mods to.
Thanks,
Chris
Old May 13, 2020 | 02:08 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Re: Took the plunge
Pics!
Old May 13, 2020 | 03:58 PM
underdave's Avatar
Car: '91 Firebird vert
Engine: 305 TBI
Transmission: auto
Re: Took the plunge
That's what it costs for the top and install? Ouch, I didn't expect that much!
Old May 14, 2020 | 09:57 AM
Engine: 350 TPI L98
Transmission: WC T5
Re: Took the plunge
It goes in Monday and will take 3-days to a week. I will put up plenty of pics. The shop has a lot of experience so I am hopeful they will get it right. My current top looks like it shrunk all over. The sides behind the door windows is pulled up and curled at the bottom and pulled apart on both sides at the stitched seams. Also, to close the top there is a lot of tension between the front and back and often when I drive the back pops out of its latch. I did try to stretch it in the sun with some improvement.
Old May 15, 2020 | 08:52 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Took the plunge
I did most of the prep/removal during the week after work. Maybe 1-2 hrs a day and it still took me all weekend (8-10 hrs/day) to install mine, but it is do-able.The top comes oversized so you have to trim it where it attaches/glues to the frame. Installing the headliner was slightly easier.
Old Jul 31, 2020 | 04:27 PM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Took the plunge
Best top video, IMO. What say yous?
puma1552
Mar 26, 2012 08:52 AM
1986CamaroSC
Aug 9, 2002 08:44 PM
