Rear Hatch Release
Old Mar 11, 2021 | 04:42 PM
Don Ho's Avatar
Rear Hatch Release
I can't get my rear vert hatch open , any ideas on how to release the hatch
How can I realease my rear vert hatch if this doesn't work ? ?
Old Mar 11, 2021 | 08:31 PM
Don Ho's Avatar
Re: Your Convertibles
I just got a 92 vert , I can't get vert hatch open to fold the top down , is this switch electric ?
Old Mar 11, 2021 | 10:14 PM
Speedgraphic's Avatar
Car: '90 RS Vert
Engine: 305 TBI
Transmission: 700-R4
Yes it is electric. It fires a couple solenoids that release the toneau cover. There is one on each side.
The good news is that there is a manual release. If you fold the seat down you can see those solenoids.
Attached o each one is a loop. Pulling on that loop manually releases the cover.
There are two safety devices that keep this thing from deploying by accident.
The car must be in park (or neutral I think) for the solenoids to work AND the
Trunk must be closed.
Be sure the car is firmly in park.
Be sure the trunk is closed.
There is a switch at the top of the trunk that senses if the trunk is closed.
You can bypass the switch if you have to.
If your neutral safety switch on the shifter is bad it won't function.
One other thing is to check fuses.
Congrats on getting one of these Verts!
Old Mar 12, 2021 | 01:52 PM
Don Ho's Avatar
Loop where ?
I tryed the nuetral (5spd manual) and trunk closed , key on ,checked fuses , nothing . Now I'm looking for the loops , am I looking in the right area ? Did you get the other two messages I sent you before this ?
Old Mar 12, 2021 | 03:06 PM
Car: '90 RS Vert
Engine: 305 TBI
Manual Release Loops: You might have to feel around behind the sail panel. It had been so long since I had needed to find mine that is what I had to do for this shot.
Old Mar 12, 2021 | 03:11 PM
Car: '90 RS Vert
Engine: 305 TBI
In the trunk you will find the trunk switch. Some of these incorporate a pulldown instead of just a latch. These sometimes malfunction. Here is a picture of the top and bottom parts of this. If you look behind the Back trunk trim you will see the wiring for the trunk switch. You can disconnect and bypass the switch to see if it is the problem. It's purpose is to keep you from raising the tonneau when the trunk is raised and thus avoid crashing them together...
Old Mar 12, 2021 | 03:56 PM
Don Ho's Avatar
Thank You SO much ! I sent you a message thru email , I thanked you for All the important info you gave me ! I found no info anywhere in the manual or on you tube , or online about this problem . You really gave me a chance !! Thank You again and I'll keep you posted , Thanks SpeedG !! :-)
Old Mar 29, 2021 | 07:50 AM
Don Ho's Avatar
Hello again , Follow up on your info worked , I got behind and found one release loop , the pass. side didn't have one , but Now at least I can trace the switch . THANKS AGAIN for this great information SpeedG !!
Old Mar 31, 2021 | 05:34 AM
mikeceli's Avatar
Engine: LB9 305
Transmission: AT
Re: Rear Hatch Release
I got my Tonneau release solenoids to work by
making sure the plunger shaft was clean. I may have polished off some corrosion, with a mild abrasive.
lubed everything with WD40. (Yes, I know it is not a lubricant, but it often works best!)
I removed the solenoid to body retaining screw. I ground off the paint from the contact areas on body and solenoid. I applied Dielectric grease to said areas, to prevent corrosion. I replace the black oxide mounting screws with shiny (cadmium) plated screws.
Not my Tonneau pops open properly.
Old Aug 16, 2021 | 03:20 AM
B1CrwDwg's Avatar
Car: 1991 Z28 Convertible
Transmission: Auto 4L60
ok....after several years finally diggin into this...mainly cause I finally got hatch pull down working and had rear tore apart anyhow...SHOUT OUT TO West Coast Autoparts for the rebuilt up/down cycle switch. But here I sit not wanting to rip the interior apart to chase the wire from release solenoid relay...any suggestions...good power to relay to switch and through relay.... NO power to both solenoids OR trunk courtesy light which happens to be spliced off right side solenoid power.
Tootie Pang
Mar 18, 2017 12:02 PM
neilcase
Apr 25, 2014 10:42 PM
silverado638
Nov 27, 2011 12:07 PM
robstout3
Convertibles
May 11, 2009 09:14 AM
revilo
Sep 18, 2003 12:00 PM
