How to remove rocker ground effects?
Old May 16, 2021 | 08:02 PM
hw4mike's Avatar
Car: 1992 Camaro Z28 Convertible
Engine: LB9
Transmission: T5WC
Axle/Gears: 3:08
I need to remove all of the ground effects on my 92 Z28 convertible. Everything except the lower rocker one seems straight forward. Everything I've seen says there's a stud and nut in the rear quarter. If there is one on the convertible there's no way to access it. Because my car has reinforcements inside the quarter. If you've removed the lower rocker ground effects on a convertible. How did you get the back of it off?
Old May 17, 2021 | 05:27 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Transmission: TH700R4
Re: How to remove rocker ground effects?
Not sure if this was done the same way on a car as late as 92, but on my 86 this bolt was relocated a couple of inches to just inside the wheel well instead of inside the quarter panel. Hope that helps.
Attached is a pic of the inside of the bracket on mine, showing how it was moved closed to the back edge.
Ken
Old May 18, 2021 | 10:50 AM
hw4mike's Avatar
Engine: LB9
Transmission: T5WC
Axle/Gears: 3:08
Thanks for the picture Ken. I checked mine and it isn't attached in the rear wheel well. As of now I'm thinking my only option is to cut a peep hole in the middle of the reinforce to see if there's a nut holding it on.
Old May 18, 2021 | 12:09 PM
ChevyKen's Avatar
Car: 86 IROC Convt
Engine: 305TPI
Oh okay - that sucks..
However, you should be able to at least verify that the nut is there by removing the vent in the door jamb. I stuck my phone in there to take a pic, an actually got my arm in there far enough to pick up a piece of tubing that had fallen off at some point.
So, it is probably tricky, but it should be possible to get to it and losen it from the vent.
Ken
Old May 19, 2021 | 08:15 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes you can get to it through the vent opening. I removed the drain tube and since i have big arms I gave my wife my 1/4" ratchet and had her remove the speed nut.
Old May 26, 2021 | 11:28 PM
dagwood's Avatar
Top Answer: 1
Car: 1986 Camaro Drag Car
Engine: 383 on Ethanol
Transmission: Automatic
I cut a hole in the reinforcement on the Trans Am vert. Wasn't a big deal......but I wish I would have thought about the vent
Thirdvert89
Apr 5, 2019 07:43 PM
jloh
Convertibles
Feb 18, 2012 03:45 PM
peterc005
Dec 1, 2011 04:55 PM
ted gerlach
Exterior Parts for Sale
Jan 7, 2009 05:55 PM
89ragtop
Jun 24, 2002 06:55 PM
