Are Aluminum radiators worth it?
Old May 29, 2002 | 02:55 PM
SeeYa's Avatar
Car: 91 RS
Engine: 5.0
If so, are there any out there that dont need to be adapted to fit our cars. Also will adding headers to a car require a better radiator?
Old May 29, 2002 | 03:24 PM
vjo90RS8's Avatar
Car: 2002 Z28
headers will not require a better radiator. I have the stock radiator with a 180* stat and my car stay very cool. If i were you, i would mount a toggle switch in your car so that you have full control over the fan. My car does stay cool but when i do alot of stop and go city driving it does start to heat up. My AC is removed but the AC control are still hooked up, so i can turn my fan on by just putting the controls on an AC setting. Dont think a aluminum radiator would be worth it until you are producing a large amount of power.
Old May 29, 2002 | 04:11 PM
85wilrocu's Avatar
Autozone has a nice aluminum rad, for like a 100 bucks!
Old May 29, 2002 | 04:34 PM
MikeS's Avatar
I'm using the Autozone radiator on my car right now. Yes, it has plastic ends, but the important part, where the heat transfer happens, is aluminum. Much lighter than the all metal one that was on there, and cools noticably better too. I never did like the plastic ends on it, but for the price with a lifetime warrenty and aluminum fins, I think it was worth it ($117 maybe). Personally, I wouldn't look at any high end all aluminum radiators for a daily driver / stockish car.
Old May 29, 2002 | 04:37 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Is it basically a stock type replacement? Mine looks like aluminum too...it appears to be the stock 88 GTA radiator...
Is the autozone rad. a 3 core??? What is the part #?
Old May 30, 2002 | 09:14 AM
SeeYa's Avatar
Car: 91 RS
Engine: 5.0
So at what horsepower level would you guys recomend getting one 300, 400?
Old May 30, 2002 | 11:02 AM
NTChrist's Avatar
Yeayea, I want details about the AutoZone rad, and a part #, too.
Old May 30, 2002 | 09:13 PM
fourthqtr2's Avatar
Car: '88 TA
aluminum radiators
hey mike s.......i have an autozone right across the street from me....do you have that part # for the aluminum radiator for an '88 5.7L?........thanks
Old May 30, 2002 | 11:16 PM
breathment's Avatar
#433918 for aluminum radiator single core that weighs 19.7 lbs, with a tranny cooler.. i dont know if autozone offers them without tranny coolers or not..
i replaced my copper one, and i like this one alot more.. it is lighter, looks cooler, and so far has cooled just fine in texas heat.
Old May 31, 2002 | 09:06 AM
Engine: LS3
Transmission: 6L80E
Sounds like the stock replacement for what I have in my GTA...I am not sure if the ol 406 would like it or not...I will have to check it out...
THanks!
Old Jun 1, 2002 | 05:02 AM
irocz_ca's Avatar
i thought there were some irocz and gta that came with stock aluminum rads. maybe i am just wrong. anyway, if there is much difference in weight between alum and stock rads, that can be beneficial, in terms of weight reduction.
Old Jun 1, 2002 | 02:31 PM
Morley's Avatar
I thought ALL IROC's with the HD cooling system came with alum rads, I know mine did.
~M~
Old Jun 1, 2002 | 03:04 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
I think from 87 and up all of the cars got the aluminun radiators. I know that my 90 RS has it.
Kat
Old Jun 1, 2002 | 11:47 PM
Shagwell's Avatar
Car: projects.......
I went from a factory three core copper to an Autozone OE replacement 2 core aluminum, and was thankful that I did. I have the 160 fan switch, and a 160 thermostat, and still was running around 220 in town. The radiator dropped me to my 160, and it just sits there, ALL THE TIME. To me the radiator was the best thing I ever did for my cooling. - oh, and I'll get the part # for you guys, I work there...
Old Jun 2, 2002 | 08:20 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I went to Autozone (online) and the only plastic and aluminum radiator they listed was a 1 core. It's made by GDI, part # 433918.
Is this the one that is supposed to the the best for the money? Even better then the copper 3 core they have?
Old Jun 2, 2002 | 08:46 PM
breathment's Avatar
ya, the 1 aluminum one is better then the 3 core copper.. iv had both..
Bubbajones_ya
Jul 6, 2024 08:32 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Bohemian
Aug 15, 2017 05:11 PM
gta892000
Sep 16, 2015 12:37 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
