Edelbrock Water Pumps
Old May 31, 2002 | 04:05 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Anyone running one of these?
Any problems with it?
They're supposed to run abt 20 degs cooler, but I recently saw a post reporting they have a short lifespan.
Also, heard a stock water pump can be modified to be a high flow.
Anyone know anything abt that?
Old May 31, 2002 | 04:47 PM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I've got one and I like it. It did drop my temp and what I also like about it is that it is rebuildable if needed. There are better pumps out there, like stewart, but for the price it's not a bad pump. I've also had it on the car for 3 yrs.
Old May 31, 2002 | 08:41 PM
Jza's Avatar
Jza
I've also had one for a few years. Nothing wrong with it, but go ahead and get a Stewart.
Old May 31, 2002 | 11:26 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
What are the strong points with the Stewart?
Thx
Old Jun 2, 2002 | 09:19 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Re: Edelbrock Water Pumps
By attaching a thin solid plate to the back side of the stock stamped out impeller it's supposed to increase the impeller efficiency and make it pump a lot better. I've seen the kit in summit, it uses rivets to attach the plate. I made one myself at work and it does help cooling. You can also port the casting out to match the gaskets for improved flow.
Old Jun 2, 2002 | 12:51 PM
JPrevost's Avatar
Car: 91 Red Sled
Thx
Everything. Seriously, there isn't a better mechanical waterpump company out there!
They have 4 stages. The 1st is stock housing but all new parts with tighter colerances. 2nd stage is the big jump, aluminum housing, all around it's like the edelbrock pumps but better .
The prices are great so if somebody could come up with a reason not to us them over anybody else it would probably look like, "well I got a really good deal on this from a friend...." else, get a Stewart.
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
