Correct wiring for turning both fans on with switch..???
Old Jun 3, 2002 | 07:26 PM
automorph's Avatar
Car: 89 Trans Am
Engine: 3.1 V6
Could someone please post the simplest way to wiring up a switch to turn on both fans WITHOUT melting, cutting, shorting, taping, and just destroying the wiring...... THANKS
Old Jun 7, 2002 | 06:46 AM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You need to ground the primary relay.. They are tied together with a greay wire. Find the "trigger" line on the relay, which enables the circuit when grounded and you'll be all set..
If you can't find it, I can look and tell you which wire to connect to but its fairly trivial.
-- Joe
eightsixseven
Dec 16, 2024 01:50 PM
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
ZsTransAm
Aug 11, 2015 07:30 PM
