Re-charging AC
Old Jun 8, 2002 | 03:03 PM
zach's Avatar
Re-charging AC
Can some one tell me how to re- charge my AC?
1985 Trams Am
Old Jun 8, 2002 | 04:57 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
It depends.
What type of refridgerant is in the system now, R12 or R134a?
If its R12 and empty or very close to being empty get a retrofit kit and a can of stop leak-oil-leak detector. The kit comes with all the information, fittings and other parts needed to retrofit and refill a system. Its always best to replace the orafice tube then pull vaccum on the system -5psi for 15 minutes before charging but its not always nessasary.
If you want step by step how to instuctions just ask. It takes about ten minutes to type it all out but I could hook you up.
Old Jun 8, 2002 | 08:54 PM
zach's Avatar
I'm not sure what type of refregerant I'm running. The system is empty. Where is the best place to get a kit??
Thanks for your help..
djmarch
Jul 24, 2012 03:15 AM
stvenracer
Jul 2, 2012 07:47 AM
djmarch
Jun 30, 2012 07:15 PM
Jason E
May 24, 2011 02:31 PM
