Trans temp?
Old Jun 8, 2002 | 10:47 PM
FIRECHICKEN's Avatar
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Trans temp?
What should the trans temp be for normal driving? Also where is a good place to install the tempreture sender for an aftermarket guage. Somewhere that doesn't require drilling would be good.
Old Jun 9, 2002 | 07:02 PM
Desert86Roc's Avatar
Different stall converters will run at different temps. As far as a sender, they usually specify installation in the pan, like where your drain plug is.
Of course, that is provided you have a drain plug, like in an aftermarket pan.
Bstrang6
Sep 8, 2015 04:29 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
Hello, Michael
Aug 20, 2015 03:19 PM
bamaboy0323
Aug 15, 2015 07:20 AM
