always overheating
Old Jun 20, 2002 | 02:31 PM
jcjohnston78's Avatar
always overheating
i have had my 92rs305TBI since 99 and has always overheated in the summer with the ac on....i had an easy solution "dont use the ac" But this summer its even worse....now its overheating with or without the ac on....when driving on the streat with stop lights traffic it overheats without the ac on in about 20 minutes of driving...with ac on it overheats in less than 10mins. I live in texas so at this time of year its pretty hot and its only gonna get hotter.
ive checked everything, ive had different mechanics look the car over....ive had everything that could cause the over heating fixed or changed.
do have u guys have any ideas or suggestions that might help cool my car down or maybe things i havent havent checked
ive changed my radiator, air dam is good, freeze plug been checked, electrical fan is always on when the keys in, ive got a 160 stat. water pump looks good but im thinking about putting a high performance pump on.
thanx
james
Old Jun 20, 2002 | 11:37 PM
Desert86Roc's Avatar
A friends RS did the same thing. After verifying that you gauge is actually reading correctly (they are notorious for being WAY off. Mine is 30* off), we added a dual fan setup and it cured the problem. You can also add an engine oil cooler.
Different areas of the country (TX, AZ) just need a little extra cooling help. That is why some f-bodies came from the factory with engine oil coolers.
Old Jun 21, 2002 | 10:45 PM
you wouldnt have any pics of the fan setupu got...or do u know off what dual fans setup it was
thanx
james
Old Jun 23, 2002 | 01:55 AM
Blackened's Avatar
Off an IROC ?! U didint know some Z28s and IROCs came with dual fans ?
Old Jun 23, 2002 | 04:35 PM
iroc22's Avatar
Dual fans came on the 88-up TPI cars. Some 87's may have received them also.
Old Jun 30, 2002 | 10:07 PM
91'firebrd's Avatar
Look at the problem the other way, instead of massive cooling, why is it generating so much heat?? I've driven my Formula for almost 8 years over 100,000 miles in Phoenix stop and go and have never had a cooling problem. Even run the car in super hot garage with AC on (since I live in Phoenix, my AC never is turned off) and car will stay under 220 for 10 minutes or so. Coat your headers and run synthetic oil. Make sure advance is not too high.
Make sure fans spin the right way, blows hot air on engine.
Old Jun 30, 2002 | 10:28 PM
And what engine do you have in your 91???? A V6? A stock radiator will cool a V6 all day long, but the same stock radiator (which almost all f-bodies have), is not always sufficient to cool a 305, let alone a 350. GM recognized this problem and had different solutions. Some later 350s (many in AZ) came with factory oil coolers to in addition to a dual fan setup. Not to sound skeptical, but I have owned f-bodies in Phoenix since 1984, and any with a V8 CAN run hot when the temps are over 105* outside. Anything below that, and you can usually cool anything (even my 406).
Old Jul 2, 2002 | 07:54 PM
91'firebrd's Avatar
I have a 5.7 liter, you have seen my car at the track.
Red Formula.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
mustangman65_79
Sep 1, 2015 03:51 PM
JHX
Aug 29, 2015 02:30 PM
jbd1969
Aug 17, 2015 07:06 PM
