A thought on cooling fans.
Old Jul 7, 2002 | 07:27 PM
Jokerman's Avatar
Engine: slowtacular L03 305
Transmission: slushem 700r4
I am wondering if it would be easily done to take the twin fan setup off of a tpi car and swap it onto a tbi car and then piggy back the secondary fan so that it turns on with the primary (left and right). Then your tbi could function off of the stock fan switch and such. Just an interesting idea for a cheap cooling upgrade.
Old Jul 8, 2002 | 06:01 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Can be done. You will need to know how your fan on the TBI is turned on. Most of the TBI units I have looked at use the fan switch in the block and the AC pressure switch. Consult a wiring diagram for you specific application. Assuming you use the system mentioned you will need to have TWO fan relays. One relay cannot handle the current of two fans without failing in a short time. The fan switch should handle both relay coils without a problem.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
formula1LE
Sep 12, 2015 08:31 PM
IROCZ1989
Sep 4, 2015 11:54 AM
