Stop and go = TOO HOT H E L P!!!
Old Jul 10, 2002 | 04:25 PM
craiger's Avatar
I need HELP! I put a new engine in my Z around xmas. The only changes were AFR 190 heads, and a cam jsut a little bit larger than stock...208/222 on 112lca. and compression is about the same (9.3/1). I think the only real change is that i took the header wrap off my headers and I had considered that this could be causing my temps to get so hot?
When I am in stop and go traffic or if sitting still, my car gets really hot? I have both fans comming on around180deg and stay on until they cool just below that. I have always run a 160 fail safe thermostat and do not know why I am running so hot? Both upper and lower radiator hoses are hot when warmmed up. The car cools down when on the freeway but MAN! I have no idea wut's up? can anyone help? Also, how can i check to see if both fans are working?
Thankyou all in advance!
Old Jul 10, 2002 | 04:29 PM
craiger's Avatar
I forgot to add, I can see coolant running properly when i take the cap off. also, I just purchased a new radiator cap. ????
Old Jul 10, 2002 | 05:16 PM
craiger's Avatar
When I jump pins a +b on the aldl, the fan on the drivers side turns on but not the passengers side.
Old Jul 10, 2002 | 08:00 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
need to see if the fans are coming on in the stop and go traffic try to pull into a parking lot next time it is getting hot and see if the fans are coming on. my guess would be that they are not. are you running at least 50% water?
Old Jul 10, 2002 | 08:03 PM
craiger's Avatar
50\50 with some water wetter. I only drive at 6am for the most part since i work 24 hr shifts. I rarley drive in traffic and did today,hence, my concern!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MSRed91Camaro
Oct 6, 2015 01:56 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Racerx974
Sep 19, 2015 10:16 AM
bryan623
Sep 19, 2015 10:13 AM
