Changing Stock Electric fan
Old Jul 10, 2002 | 11:15 PM
GKK's Avatar
GKK
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
I have a 91 305 tbi and want to change from my stock electric fan to a higher cfm 16" electric fan. Can I just cut the two factory fan motor wires and connect the new fan wires to it using the same factory relay? I'm getting a "Perma Cool" 16" electric fan that flows 2950 cfm of air and draws 9.5 amps.
Old Jul 11, 2002 | 12:11 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
yes
Old Jul 11, 2002 | 12:20 AM
mrbboy's Avatar
Is that fan going to bolt right on without any modifications other than the wiring? Will that fan in there? IT sounds a little big. The reason I am asking is because I too have a 91 RS with the single fan. If you don't encounter any problems with this setup, then I might also look into changing my fan.
Old Jul 11, 2002 | 05:18 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
I did a search on "Perma Cool Fans" and found that their claims and quality were lacking to say the least.
Your better off getting stock IROC dual fans for around $150 used complete kit.
Old Jul 11, 2002 | 09:44 AM
GKK's Avatar
GKK
Thanks John Millican, I'll see if I can find that fan setup around my area. I almost ordered the Perma Cool fan this morning. Also, can I use my Single Fans Relay for the Dual Fan setup? Or do I have to change to a stronger Relay for the Dual Fan setup?
Old Jul 11, 2002 | 09:54 AM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i am not sure
but i think you need another relay
Old Jul 11, 2002 | 10:00 AM
http://www.metzlerracing.com/dualfans.htm
in case you didnt see it below. i got one of those parts for sale
Old Jul 11, 2002 | 11:55 AM
8.2L Trans Am's Avatar
I have perma-cool fans on my car and they seem to work well. They do flow alot more CFM than the old ones exept when you use them as a pusher. They say somthing like only 80% efficiency as a pusher but it seems more like 60% to me. The relay switch I got from them was pretty cool you can connect two fans to the one relay wich would probably work good for you.
Old Jul 11, 2002 | 11:56 AM
I took these pictures when it was raining.
Old Jul 12, 2002 | 11:24 AM
GKK's Avatar
GKK
After much research, I ordered the Perma Cool 16" electric fan. I'll post pictures after I install it.
Old Jul 12, 2002 | 11:48 AM
yeah please post pictures and results
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
customblackbird
Aug 15, 2021 10:16 PM
Ikes 91Z
Dec 9, 2015 03:49 PM
Leggman1
Aug 6, 2015 04:15 AM
