Keeping it cool.
Old Jul 17, 2002 | 09:26 AM
TA5LiterHO's Avatar
Car: 1984 Trans Am WS6
Transmission: 700r4 Highly Modified
Keeping it cool.
If you want to keep your third gen cool. Get an aluminum radiator and a 160 degree fan switch from hypertech if you have an electric fan/s. My Trans Am operates at around 175 degrees even when it sits idle. It is also important to make sure you have your antifreeze and water mixture correct. This makes a difference believe it or not. Another good idea is to wire in an override switch so you can operate the fan/s when the car is off. This is helpful when you want to run some cool air over the engine while in line at the drag strip.
Old Jul 17, 2002 | 11:00 AM
1987fbd's Avatar
IMO that is too cold. Mine would run like sh*t. But hey if it works for you
Old Jul 17, 2002 | 12:59 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
mine carb seems to be better at about 180*, so i just threw the 180 stat back in there
Old Jul 18, 2002 | 12:50 PM
TA5LiterHO's Avatar
brodyscamaro. What are your ET'S?
Old Jul 18, 2002 | 12:56 PM
TA5LiterHO's Avatar
1987FBD. No offence, but 175 is not too cool. 180 is the stock operating temp. That is only 5 degrees less. 180 is the temperature you need to run a stock engine. If you have a 305ci carbed motor thats above 350 hp like mine you need to run a little cooler temerature. So 175 is not too cool.
Pac J
May 17, 2020 10:44 AM
customblackbird
Oct 1, 2015 04:30 PM
Giocio
Oct 1, 2015 12:20 PM
ndndndnd
Sep 28, 2015 08:00 AM
lakeffect2
Sep 7, 2015 03:52 PM
