replacing thermostat...
Old Jul 23, 2002 | 09:20 AM
CamaroEFI's Avatar
while i was putting the thermostat housing back on i noticed that the top of the bolt connected to the intake manifold is totally missing the threads so i can't bolt it all away on. is there another way to fix this other than replacing the manifold?
Old Jul 24, 2002 | 09:52 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
tap it
Old Jul 28, 2002 | 05:56 AM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
I keep my stuff a long time and work on everything I can do myself. I don't think GM ever puts anti-seize on any steel bolt going into an aluminum manifold. If you can get the bolts out, and the threads are good, put studs in the manifold for the thermostat, distributor hold down, carb, brackets, etc. If you break a bolt off you'll have to drill it, and use an easy out to get it out. If the threads in the manifold are damaged you can use a tap to take it to the next larger bolt size. You can carefully drill the hole in the thermostat housing out to match the new bolt size and keep your manifold. If you continue to use bolts, you gotto use anti-seize (or formagasket if the bolt is going into a place where water or oil might try to come up by the threads)
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
