Engine getting real hot what to do?
Old Jul 29, 2002 | 05:06 PM
LUPS's Avatar
you should get the thermostat checked out maybe it is not opening when it should. also check the radiator to see if the lines are not clogged if so get the radiator flushed or get a new one.
Old Jul 29, 2002 | 05:10 PM
BillZ28's Avatar
Car: 84 Z28
The radiator in it is new also, replaced with the thermostat.
Old Jul 29, 2002 | 06:05 PM
MouseCamaro305's Avatar
also, check to make sure your air dam is fully functional
Old Jul 29, 2002 | 06:23 PM
BillZ28's Avatar
Car: 84 Z28
ah, the air dam is cracked in two places, but it is still on, but bent in a few spots.
Old Jul 29, 2002 | 07:23 PM
jamesbern's Avatar
Pressure check the system for leaks and check or replace the radiator cap. Also make sure your fan is working if it heats in stand still traffic.
Old Jul 29, 2002 | 07:46 PM
BillZ28's Avatar
Car: 84 Z28
Yea the fan does work. Is there anyway to make it go on earlier then around the 220^ mark?
Old Jul 29, 2002 | 07:53 PM
jamesbern's Avatar
Get a lower temperature switch from Summit, Jegs, anybody or wire it up manual like mine. If it is getting very hot you have another problem though. Go get a new radiator cap, fill the radiator and look for the leaks, they will be there.
theshackle
Mar 5, 2017 06:37 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Leggman1
Aug 6, 2015 04:15 AM
