Can I change from a clutch fan to an electric fan?
Old Aug 3, 2002 | 04:47 PM
AT4 T/A's Avatar
Car: 1989 IROC-Z
Engine: L98 350
Transmission: New 700r4 Done by 11/14/07!
Is it possible to change my current clutch fan setup to an aftermarket electrical fan system? What do I have to do? I did a search, but I didn't get any useable information.
Old Aug 3, 2002 | 10:24 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, you can do that. you could evn use a stock one if you could find one.
You need a temp switch, which ordinarily mounts in the head, you can use a stock one or any other that peels your banana; a relay, which you can get one from GM or elsewhere; and a fan. Hook a large wire from battery to one contact of the relay, and the fan to the other contact so that it gets power when the relay is energized; hook one lead of the relay coil to ignition, and the other lead to the fan switch.
That's all there is to it.
Old Aug 4, 2002 | 12:44 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Don't disclude the Hayden fan switch/relay that breaks w/in a year.. :grumble:
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Hellbillydeluxe
Sep 22, 2015 09:58 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
