Will a V6 radiator work with a 350?
Old Aug 11, 2002 | 12:16 AM
fast83camaro's Avatar
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Will a V6 radiator work with V8? I have noticed the top outlet on the other side. Would I have to get a custom radiator hose? Will it cool enough for a 350?
Thanks in advance
Old Aug 11, 2002 | 01:05 AM
LowStyle187's Avatar
I dont know but mabey there is a reason they ask you what type of engine when you go and buy a new radiator. Dont take the cheap way out cuz your car will not cool properly. But are you using a old radiator from a V-6 to drop into a car with a 350? Well as long as the connections hook up the same and its not cracked and you keep it filled up then i would say try it until you get the cash to get one that is made for that engine. Hope that helped
Old Aug 11, 2002 | 01:14 AM
Well, I was just wondering b/c I have a V6 parts car with one, and my originally V6 car didn't have motor, tranny, or in this case... a radiator! And I am doing the 350 swap. so I guess I'll just have to go to Skippy's (the local junkyard) Monday and look for a V8 car with a radiator.
Thanks for your help!
Old Aug 15, 2002 | 10:51 PM
MIG-29's Avatar
Car: 1987 Camaro
Engine: 1986 350
Transmission: T-5 NWC
NO it wont work.
i've tried before, when i wento from v6 crap to V8, neither with 305 nor 350 (done them both)
it will fit the compartment, but the upper hose (looking from the pilot seat) on V8 is on the left, on v6 is on the right. and some other diff's.
Fernando.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
djmarch
Aug 11, 2015 10:22 AM
milk
Aug 10, 2015 06:26 PM
