Tell me if this is a fan switch?
Old Aug 13, 2002 | 10:11 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I went to pick a part today and got a couple of fans to replace my mechanical fan. I pulled these to "things" off a buick. Is one off them a fan ground switch that runs the relay. I plan on running both fans off one temp switch, with a toggle shut off when I race. But any way is one of these what I want?
Old Aug 14, 2002 | 12:32 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I got it figured, The two wire is an RTD (resistive thermal device). The one wire is infact a temp switch.
Old Aug 21, 2002 | 01:44 AM
305iroc's Avatar
Car: 91 Z28
Transmission: 5 speed
Axle/Gears: 3.42's
What temp.
About what temp did you want the fan(s) to come on? Hypertech makes to different temp switches. 176 on,166 off(part#4026) and 200on,185off(part#4028). They run about 44$ if you want to spend the $.
Old Aug 21, 2002 | 10:59 AM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
Yeah, I got the stock switch working but no go till 230, so went and got the Jet 195 on 180 off. Works great with my 160 stat, beacuse on the hiway the fans never come on. Loosing the 20lb fat metal fan and going electric was one of the best mods I've ever done, gained another 200 - 300 rpm reving top end. Now she climbs hard to 6700, but I usaully dont push it past 6000.
Old Aug 22, 2002 | 08:50 AM
MdFormula350's Avatar
sounds like you have everything under control, great job!!
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
