Rad cooling question
Old Aug 17, 2002 | 12:56 AM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Ok....I tried a search, but can't remember what this thing is called, which made it difficult!
The plastic "fin" underneath the engine, which directs air flow to the radiator. The one that gets scuffed all the time. I was simply wondering this : If I remove the air conditioning rad, will I still need this fin? I figure that removing the air con one would allow a passage of air to the rad. Am I correct here?
Many thanks,
Si
Old Aug 17, 2002 | 01:26 AM
Sciguyjim's Avatar
That fin below the radiator is usually called the air dam. I'm sure you'll still need it after you've removed the AC radiator. At high speeds the rad fan turns off and the cooling air all comes from underneath. Without this piece, the engine temp will be ok at low speeds but it will get hot at higher speeds.
Old Aug 17, 2002 | 05:43 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The air dam is the primary source of air flow to the radiator at speeds over 35 mph since these cars have no front grille. Remove it and your engine will run very hot, depending on ambient temp dangerously so.
Old Aug 17, 2002 | 12:10 PM
si_camaro's Avatar
Car: 85 Z28
Hey thanks for the input guys. I'll leave it on then! The only reason I thought I might get away with it off is the fact that through the bottom of the front bumper (fender?) - it has an IROC front bumper I think, the one with the 2 holes either side of the word Camaro - I can see straight through to the air con rad. I figured that was the only thing in the way. Hey, no big deal. The reason I wanted to remove it was because in this country, the roads can get rather bumpy...and of course there are speed humps everywhere. It tends to scrape the road a lot!
Thanks again,
Si
Old Aug 17, 2002 | 05:46 PM
Sciguyjim's Avatar
Si_camaro,
Perhaps you can use the openings you mentioned as a place for a cold air intake. It's nice to have ready made openings like that.
Old Aug 17, 2002 | 06:29 PM
si_camaro's Avatar
Car: 85 Z28
Originally posted by Sciguyjim
Si_camaro,
You know, I was thinking the very same thing not so long ago. I might have got the description wrong about my front bumper, but I think it's an IROC one. I was thinking of getting some kind of guttering or similar, and attatching it to a hose directly to the air filter housing. Will this affect the cooling in any way, if I use it for that purpose, and therefore stop the air getting past the bumper?
Here's a pic of the car. If it's not an IROC bumper, can someone tell me what it is? Nobody can give me advice on these American "imports" !
Old Aug 17, 2002 | 09:26 PM
Sciguyjim's Avatar
Since you're keeping the air dam in place I'm guessing you'll be ok if you block part of the airflow through the openings. I can't help with the type of bumper you have, I have a '89 Trans Am. It has no openings in the bumper at all. At high and low speeds 100% of the cooling air has to come from below the rad.
chazman
Aug 28, 2018 03:25 PM
91 rally sport
22
Apr 5, 2016 05:06 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Leggman1
Aug 6, 2015 04:15 AM
