Bubbling into resv.
Old Aug 21, 2002 | 07:22 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Bubbling into resv.
Hey I just bought a 1989 Iroc Convertable and am having problems........it did not overheat but when I turned it off there was a bubbling in the over flow tank. I squeezed the upper radiator there was nothing in it. The hose was hot but no fluid in it that I could tell. I just replaced the thermostat 195* and my fan is coming on. Any Ideas???
Brian Felts
Old Aug 21, 2002 | 07:44 PM
mckenzie's Avatar
does it bubble in overflow running at a idle?
Old Aug 21, 2002 | 07:59 PM
Well I will have to check that out......I didn't notice it until I turned the car off. I just put a new thermo in. I did think it was strange the upper radiator hose was hot but empty.
Brian Felts
Old Aug 21, 2002 | 09:26 PM
breathment's Avatar
try a new radiator cap..
Old Aug 22, 2002 | 11:30 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
Yeah, get a new radiator cap. Also make sure you have enough coolant in it.
Old Aug 24, 2002 | 08:26 PM
Ryan_Alswede's Avatar
Car: 1992 Camaro RS & 1992 Camaro RS
Engine: 3.1 L v6 & 305 (5.0L) v8
Transmission: 4L60 Auto
Everything you describe is normal, water expands thats why there is a catch tank. If your cap is old, yeah replace it but the upper radiator never is full full just returns hot water to the radiator.
tom1985
Apr 19, 2016 07:55 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
BWilcox
Sep 20, 2015 12:19 PM
84redta
Sep 19, 2015 09:58 AM
86iroczwv
Sep 3, 2015 06:21 PM
