Fan only runs when the car is on.
Old Aug 24, 2002 | 11:07 PM
Mike91rs's Avatar
I've noticed that when I turn my car off after running her all night, the fan isn't kicking on. when the key is turned over, the fan kicks on, but if the car is off then it wont. Does anyone know the cause of this???
Old Aug 25, 2002 | 12:45 AM
breathment's Avatar
the fan is only supposed to run when the car is on.. The power for the fan is switched on when the ignition is turned on..
Old Aug 25, 2002 | 11:22 AM
Mike91rs's Avatar
cool, it's just that I thought that the fan would kick on it the engine was hott enough. Ya'know, like almost every car out there today...Thanks though for the reply
Old Aug 26, 2002 | 10:46 AM
MdFormula350's Avatar
yeah you sound fine, if the fan(s) ran after the car was off then you can wave bye-bye to you battery...
Old Aug 26, 2002 | 05:22 PM
Mike91rs's Avatar
Cool thanks man...
Old Aug 26, 2002 | 06:49 PM
kevinc's Avatar
Car: 1982 Z28
The fan power is full-time, it's direct fed via fusible link off the batt positive at the starter. It's the relay pull voltage that's switched. The relay can't close without it, so no fans.
Old Aug 27, 2002 | 02:22 PM
Soulrev's Avatar
Car: Formerly - 87 T/A, 87 Bird.
my fan is wired up via toggle switch so it stays running when the car is off, until I turn the switch off. There's really no point in running the fan if the car is off though, unless you're overheating.
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
86IROC112
Aug 17, 2015 02:00 PM
Leggman1
Aug 6, 2015 04:15 AM
