Best cheap water pump for 92 383
Old Aug 26, 2002 | 11:33 AM
ShaneBuss2's Avatar
Car: 1992 Firebird Coupe
Engine: 357ci Carb
Axle/Gears: 3.73 posi, stock rear
Hey guys ive been looking for a good water pump for my new 500horse 383 stroker. (unless yall think the stock rad and stock water pump will keep it cool).
I saw some in summit for around $90 that are 30% flow over stock.. (midden pumps). Its kind of hard to figure out which ones i need for a 92 with serpentine belt...
Anyway is there any point in getting a better than stock water pump with the stock radiator? Any ideas? someone had recommended some stage 2 pumps that were nearly $200. I hate to spend that much on just a water pump.
Shane
Old Aug 26, 2002 | 12:52 PM
Lounge Lizard 6's Avatar
Stewart Stage I ~$70 http://www.stewartcomponents.com/
Old Aug 26, 2002 | 01:51 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
any idea how those flow compared to stock?
which one do i order?
thanks,
shane
Old Aug 26, 2002 | 10:17 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
ttt
Old Aug 27, 2002 | 09:38 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
They flow a lot better than stock. You might want to go to the web site and check out the stats. Also, you might not want the stage 1 for what your running. You might want to get the stage 2, it flows more and is aluminum. Check out their site, you'll get any and all info that you need.
Eric
Old Aug 27, 2002 | 12:21 PM
ShaneBuss2's Avatar
Engine: 357ci Carb
Perhaps the stage 2 would be better, but i just hate to spend that much money when i have a stock radiator. Probably be better spent in that.
Shane
Old Aug 27, 2002 | 01:31 PM
CraZ-28's Avatar
Car: 1991 Z-28
If it were me, I'd do it anyways. Also, it will work with the stock radiator but I'd also replace that, when the money becomes available of course. Especially since you live in TX. I know that the summers can be like they are here in AZ, brutle!
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
