Guage travels to red while car is off
Old Aug 29, 2002 | 07:44 PM
PimpRod92RS's Avatar
Car: 1992 Chevrolet Camaro RS; 1986 Oldsmobile Cutlass Ciera Brougham
Engine: LH0 3.1 Liter V6; YBN 2.8 Liter V6
Transmission: TH-700-R4; TH-440
Hello my fellow Thirdgeners:
I run about 220 now that weather is cooling down and I am aware of a freeze out plug that loves to leak, and I will be fixing that whenever time arrives. (I will keep my antifreeze level under control for the time being) But my question is why does my thermo guage like to travel towards 260 when the car is turned off and supposed to be cooling down? Is this because there are hotspots or just the way the guage likes to function? Let me know thanks, just curious not worried.
Old Aug 30, 2002 | 11:47 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Is this a stock gauge or an aftermarket mechanical one?
Old Aug 30, 2002 | 03:03 PM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
Any leak in a cooling system releases pressure. System pressure is what keeps the boiling point of the coolant high. A pressure leak makes the coolant start to cook at a lower temp, hence the increase in temperature. For every 1lb of system pressure the boiling point of the coolant rises about 3 degrees. When you shut off the car the temp will rise before it goes down, factor in a loss of pressure and thats where you problem lies.
Old Aug 31, 2002 | 11:25 PM
Why does the temperature rise normally though?
Old Sep 1, 2002 | 05:57 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
The temp rises because the coolant is not transferring heat because the water pump is not circulating, and the cooling fans shut off. When this happens the coolant temp will rise for a short period of time then slowly start to drop. It's a perfectly normal event and poses no problem as long as the cooling system maintains pressure.
Old Sep 1, 2002 | 02:25 PM
breathment's Avatar
so is that what heat soak is?
Old Sep 3, 2002 | 05:23 PM
rezinn's Avatar
I've only used heat soak on this board to describe why some cars won't start when hot, because the starter has absorbed heat from the headers. I guess you could use it to describe any other time that excess heat is absorbed by something. When your coolant temp raises after you turn the engine off it is caused by residual heat from combustion. This is why you don't race your engine to 5000 rpms and then just shut it off. It'll overheat because it has all of this built up heat but no way to cool it except for it to transfer to the rest of the engine, coolant, and oil.
Old Sep 3, 2002 | 06:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Where do you think the heat normally goes?
Old Sep 4, 2002 | 05:56 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
It is called "heat transfer" and it one of the principles air conditioning uses. Heat always travels from the hotter material or souce to the colder one. The residual heat will slowly move from the engine and transfer through surrounding materials until the engine becomes the same temp as the ambient air.
Old Sep 4, 2002 | 11:02 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Of course it does, I was just questioning the wording of what he said.
Old Sep 9, 2002 | 11:31 AM
Sciguyjim's Avatar
I've heard the term "heat soak" used a lot in reference to fuel injectors. After the engine is shut off and local temps rise from lack of cooling, as described previously, the gas remaining in the injector tips can get dried out and leave deposits. Older injectors were more likely to have problems from deposits than are newer types.
Ghettobird52
Jul 5, 2024 11:18 PM
customblackbird
Aug 15, 2021 10:16 PM
Golfvette
Aug 24, 2015 06:35 PM
Linson
Aug 21, 2015 02:12 PM
ZsTransAm
Aug 11, 2015 07:30 PM
