What temp??
Old Sep 13, 2002 | 01:26 PM
Spider7's Avatar
What temp??
I have a 305 TPI with a 180* T-stat. What temp should I be running at after the car is warm and steadies out? What temps do your guys cars run (same engine setup)? Thanks for the help
Old Sep 13, 2002 | 04:27 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
That stat won't help much at all if you haven't changed the fan temp switch. Stock the fans don't turn on till about 230* or so.
With a 160* stat, aluminum radiator I usually run about 170* down the highway, and 190* in traffic.
Old Sep 14, 2002 | 01:30 AM
Spider7's Avatar
Thanx Mark. I consistently run about 220, is that bad? Too hot?
Old Sep 14, 2002 | 06:37 AM
Danno's Avatar
Car: "02 z-28
Engine: LS-1
220 is perfectly fine for any engine. It will tend to run a little hot in city traffic, cooler when on the highway. I run a zz-4 block with otherwise all else stock. Everything in the cooling system is new GM original equipment. With a 195 stat and stock cooling fan setup as far as turn on temp etc. she runs on the first line bet 100 and 220. In traffic with the AC running it hovers just a hair below the 220 mark on the guage.
Old Sep 14, 2002 | 10:33 AM
Car: 99 Formula
Axle/Gears: 342
Hotter than I like for my motor, but for yours it's perfectly fine, that's the way they were designed to run for emissions purposes.
Old Sep 15, 2002 | 01:15 AM
Spider7's Avatar
Ok, thanx guys.
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
