Installing AC
Old Sep 15, 2002 | 03:03 AM
*84TA's Avatar
Car: 84 Trans Am
Installing AC
Has any one ever installed AC in an AC delete car. I am going to put it in mine. It is been really hot here. And it is a pian in the *** when the Windows fog. Has any one ever done this, and if so was it hard. Was everyting there you needed for the wirang and all that.
Old Sep 15, 2002 | 07:01 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
get with the guy a few threads down called "should I take out my A/C". You would need to to everything. Best to have a doner car there to do it. The doner car will need your 'delete' stuff as well.
Old Sep 15, 2002 | 07:31 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
the hardest part beleive it or not is gonna be doin your controls. You will need the control wiring for the high and low press. cut-outs, along with the compressor wiring, and relays for the comp, and the cooling fan by-pass, assuming you have an electric fan. Its not impssible, but it isnt easy.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
