manual fan switch
Old Oct 4, 2002 | 07:37 PM
1986redbird's Avatar
manual fan switch
Well, I finally installed my manual fan switch today. it lights up whenever the fan comes on, the switch allows me to chose between automatic and manual fan operation. plus I found something to put in that ugly spot on the dash.
Old Oct 4, 2002 | 11:50 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
hmmmmmmmmmm
Old Oct 6, 2002 | 02:36 PM
MdFormula350's Avatar
cool, i just used a toggle switch and let it be at that. but a light could help alot..
Old Oct 9, 2002 | 07:54 PM
SpeedJunkie's Avatar
Car: 88 IROC
Wait so that switch has three terminals: a ground a power for the light and another power . So how did you hook it up for the light to come on when the fans are computer controlled turned on? Does it light up when you flick the switch to turn them on too?
I'm confused.......
Old Oct 12, 2002 | 01:38 AM
yes it comes on when anytime the fan is on, if it is in auto everything works as it should and the ligh comes on everytime the fan does, if I switch it to manual the fan runs continously as long as the ignition switch is on.
Old Oct 12, 2002 | 09:01 PM
I'm confused.......
it has a ground terminal, a "load" terminal that goes to your fan, and a power terminal that is what gives the fan power
Old Oct 13, 2002 | 07:53 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Where did you get it/them? Jeggs has a lot of switches. The blue would match my car too! Looks good guys, nice.
Old Oct 13, 2002 | 10:21 PM
radio shack
Old Oct 13, 2002 | 10:29 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Damn! Thanks
Old Oct 13, 2002 | 11:28 PM
Damn! Thanks
damn am i your hero!!!
http://www.radioshack.com/product.as...5Fid=275%2D712
Old Oct 14, 2002 | 09:24 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Thanks man! Sure
Old Oct 14, 2002 | 10:12 PM
88Bravo's Avatar
Car: 1988 Pontiac Firebird, flat black
Engine: Stock 305 LO3
Transmission: Five speed
How do you keep the amps down throught the toggle? I have mine through a toggle, I have the power coming from the bat, to a toggle and out to the fan power line. The problem is that I keep losing the toggle switch. Is it because of to much amp going to the toggle? Should I use another power supply? Where if so? I think I have solved the problem by using a light switch!!! It may not look great, but it works. Any help?? By the way I keep the fan switch on when I drive.
Old Oct 14, 2002 | 11:15 PM
check out my posts, you need a switch that can handle more
Old Oct 14, 2002 | 11:31 PM
88Bravo's Avatar
I replied, I think I gave all the info that would be needed. What do you think I should do?
Old Oct 14, 2002 | 11:50 PM
i just meant my post in this thread. it is better to use a relay system but you dont have to. i would use 10 awg wire and get this switch - although i have this setup and am going to a dual relay setup.
Old Oct 15, 2002 | 02:01 AM
88Bravo's Avatar
I was wondering if the fan could handle the amps from the bat? I could use the toggle for the ground wire. Would I blow up my fan?
Old Oct 22, 2002 | 10:47 PM
TransAm12sec's Avatar
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
Looks nice and clean. Great job!
Old Oct 23, 2002 | 11:57 PM
breathment's Avatar
you really need to use a relay. and wire the switch into the COIL of the relay. so that when u flip the switch, the coil has current and activates the main switch in the relay. If u know how a relay works then this will make perfect sense to you. if not i can reply back with some diagrams.
Old Oct 24, 2002 | 03:41 PM
panman79's Avatar
Find out how many amps your fan runs on and run a hot to something with similar amperage in the fuse block, that kicks on when the car is started.
89GTAOz
May 16, 2020 09:31 AM
krisner89
Oct 10, 2015 06:03 AM
bryanwood74
Sep 24, 2015 09:50 PM
Ducati900ss
Sep 2, 2015 09:05 AM
TA8487
Aug 16, 2015 12:21 PM
