Installing Dual Fans...
Old Oct 26, 2002 | 01:23 AM
Keith27's Avatar
Are the dual fan set-up on 2 different relays or do they tie in together?
I have a dual fan set up and I want to put them in my 91 Formula.
Not sure how to wire it up??
Old Oct 26, 2002 | 09:57 AM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
each fan is run on it's own relay.
here's breathment's pic
Old Oct 26, 2002 | 08:42 PM
Keith27's Avatar
Can I run them together on 1 relay from the same sensor?
Im kind of confused on how I run them? It gets hot here in Texas and I think daul fans will help me keep it cooler, that and Ive got them so I might as well use them!!
Old Oct 26, 2002 | 09:08 PM
Car: 1988 IROC-Z
you can...... but it won't last that long at all. i literally burned my relay and wiring doing it that way. not a pretty site. i strongly disrecommend this method.
Old Oct 27, 2002 | 12:21 AM
Keith27's Avatar
Thanks for the info, that kills that plan.
How do I run 2 relays off 1 temp. sender? I have a sending unit that kicks on at 160 or 170.
Thanks for your help!
Old Oct 27, 2002 | 06:41 AM
Car: 1988 IROC-Z
you can wire both F terminals to that switch, i believe, w/o a problem. piggy back the new relay F term. to the old fan switch wire. the switch simply provides a ground for the relay when it reaches it's designed temperture.
Old Oct 27, 2002 | 07:04 PM
MdFormula350's Avatar
heres another one of the pics floating around, very helpful i hope
Old Oct 27, 2002 | 07:57 PM
Keith27's Avatar
That helps, Thanks
Old Oct 29, 2002 | 05:50 PM
mckenzie's Avatar
would you take both the "F" wires to the switch that tag's the wire at the ecm? i'm going to also do this project this winter, and am a bit confused. thanks, tom
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
hayesaw0210
Aug 23, 2015 11:15 PM
