Overheating Problem
Old Nov 22, 2002 | 12:35 AM
jesse23's Avatar
Overheating Problem
A few weeks ago i posted that i was leaking anti-freeze. Then i replaced the heater control valve. Then a few days later, my car started to overheat, spewing coolant and boiling water out of the rad cap. I brought into shop they replaces rad hoses, and heater control core. Now a few weeks later once again im having problems. I was leaving my friends house when all of a sudden i had like no acceleration. I looked down at my speed and rpm and noticed the temp. It was all the way to the right, way past 260. The fan was on, the water was bubbling and boiling in the reserve, but nothing spilt out. I went home let it cool off more, emptied reserve and put new coolant in. The rad is full, the tank is upto proper spot, yet still the car after a few mins of driving is getting past the 260 mark. SO once again I popped the hood, and looked around.
Old Nov 22, 2002 | 12:37 AM
jesse23's Avatar
didn't all fit
felt the rad cap (cool), felt the reserve (cool), felt rad (cool), felt top of engine (cool), felt the hose goin from rad to engine (VERY VERY VERY HOT), touched bottom of engine (was a redish color...VERY VERY VERY VERY VERY HOT!!).
My only guess is that the thermostat is off and is not allowing the coolant to go into the engine or whatnot?
I am goin to the shop tommorrow early to have them look at it, what do you all think?
BTW
91 Camaro RS 3.1 with CAI
Old Nov 22, 2002 | 09:52 PM
Andy Bush's Avatar
This is a tough one because there is a possibility it is not the cooling system with the problem but something else in the engine.
However if it is the cooling system it sounds like it is not fully primed with coolant. This is common and can happen after a system is refilled. The Camaro system has to heat an cool a few times to self prime. Also it has to have a good radiator cap.
From all the symptoms you describe it sounds like the radiator cap was the original problem too. If your engine got as hot as you describe though, you will need to check for oil consumption.
Old Nov 24, 2002 | 08:08 PM
MdFormula350's Avatar
hum when the last time you replaced the thermostat, it could of shut close! thats why everything else is cool.. just a though.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
