Never reaches thermostat temp
Old Dec 3, 2002 | 06:00 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Ever sense the weather has gotten colder i havnt been able to get my motor to a good operating temperature. It will usualy only reach about the 175 mark after some serious moshing. I have installed a edlebrock alum water pump, 180 stat, desert cooler alum. radiator and a custom air dam. Should i change the stat or simply jus put a peice of cardboard infront of the radiator for the winter? During warmer climate it runs great gets up to 180 and then cools back down.
Old Dec 3, 2002 | 09:13 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
If you can get your heat to come on, I'd say it's fine to allow it to run at 175, but I'm not a TPI guy. If you cant get it to reach your thermostat temp, then putting in a higher stat wont help. Maybe your cardboard trick is the answer.
Old Dec 3, 2002 | 10:18 PM
82camaro's Avatar
Car: 82 camaro SC
Guages and thermostat's vary in exact temperature, as well as the location of the temp sensor and thermostat. 175 sounds normal with a 180 degree stat. Toss in a 195 stat and you will run warmer. I run around 175 in the winter and around 185 in the summer with a 180 stat.
Old Dec 4, 2002 | 11:54 AM
MdFormula350's Avatar
if you have good enough heat stay with it. if not get a higher number stat.
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
FormulaEngland
Sep 30, 2015 01:50 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
