O Youll Like This One!
Old Dec 5, 2002 | 06:47 PM
RedWagon42's Avatar
ok... i kept getting pissed cuz my engine wasnt heating up i thought i had a bad temp sending unit... so i took off the hose to see if my thurmastat was stuck open... apparently when i put in my 350 i forgot to put back the thurmastat... i am such an idiot!and at this moment i cant for the life of me remember how to spell thurma-stat...
Old Dec 5, 2002 | 09:27 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
Re: O Youll Like This One!
Thermostat Well at least you figured out your problem and your outcome was one that was easily fixable
Old Dec 5, 2002 | 10:16 PM
MrsLottaBallsCamaro's Avatar
That's hilarious!
Old Dec 6, 2002 | 06:19 PM
383 rocket bird's Avatar
After wrenching for 7 hours srtaight putting my 383 in i had no power trying to start the car. I then realized that I hooked everything to the starter except for the main power cable. My dad will never let me live it down.
Old Dec 7, 2002 | 04:21 PM
RedWagon42's Avatar
one thing leads to another...
GRRR!!!!!!!!!! OK so I put the new therostat in... drive around and my car over heats! SO WHAT THE.... i pull it back out the dam piece of ****, it was bad and was stuck close... so i went and returned it got the new one and in the process of putting it in i cracked the little cast aluminum housing...!!!!!!!! I know it couldnt get any worse, ok went and got an new one of thoes it was only like 15... ok hours later my car is still overheating?? i pull over and my heater control valve EXPLODES! as soon as i open the hood draing out the entire cooling system... im guessing it was bad! so i put an new one in it was only like 15 too so starting off putting in a thermostat it turned into like 40 bucks... not a good week
Old Dec 7, 2002 | 10:35 PM
azvolfan's Avatar
Car: currently thirdgenless!!!
So is your overheating problem solved now???
Old Dec 8, 2002 | 02:45 PM
MdFormula350's Avatar
well all forget sometimes! at least i do.
Old Dec 9, 2002 | 09:48 PM
I did that exact same thing. I was pissed, and looking all around trying to figure out what was wrong, till I finally got under the car and checked that power cable.
Old Dec 11, 2002 | 03:25 PM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
Re: one thing leads to another...
you musta did something realy bad in a past life... like **** a civic or kill someone. i feel for you man. ive had all those problems happen to me just not all at once like you im sorry pal.
Old Dec 11, 2002 | 09:06 PM
92 zzz28's Avatar
Car: Guess
Engine: Crazy 8
Transmission: So close to being a manual I can taste it
On the bright side of forgeting little things, I bet you will NEVER forget again. I know I have learned many hard lessons with cars, and life for that matter.
